Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-18-2004, 04:56 PM
kuch kuch is offline
Garage is empty, add now
kuch is starting off with a positive reputation.
Hesitation Problems
I have a 1994 Ranger with a 2.3 5 sp 2wd. When I go full throttle (entering a highway) by the time I reach 45 mph the engine starts bogging down, missing, and finally stalling. I do not have this problem any other time (runs fine in city driving). I checked computer codes and replaced o2 sensor. I have replaced plugs, wires, air filter. Still no help. My hair is getting greyer on this one, and I can not afford dealer prices. Anybody have any suggestions what else I might look for...!!! ????? Thanks...
  #2 (permalink)
Old 08-18-2004, 08:14 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Welcome to FTE!
In the Power Distribution Box, which is in the engine compartment, there's a relay for A/C & WOT (wide open throttle). That's where I'd start looking.
Try calling up the dealer & ask how much this relay costs.
Hopefully, another member will pipe up to explain how to test this system because I don't have that info.
Try posting in the Ranger forum &/or the electrical forum to see what comes back.
AL.
__________________
97 Ranger (metric half ton) 2.3,5spd. Saphire blue metalic w/matching cap & Stock Rims 4 winter.
92 Town Car....Sweet PITA.
90 BII 4x4 Ongoing Project, aka PITA
63 Fairlane, Gone to my buddy Chuck.
It Aint Fun Unless It's Done The Hard Way!
  #3 (permalink)
Old 08-19-2004, 07:42 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
Fuel filter. You are asking for heavy fuel flow for a semi-extended period of time, and the filter could be flowing enough for about every other occasion, but not for full throttle over a few seconds duration. If the relay noted above is cutting out, you'd notice a chug effect as the A/C was toggled off and on. I don't think it would be enough to produce what you described. You can duplicate it's function by turning the A/C on and off manually as you accelerate, or for that matter, leaving the A/C off to check if it is really causing any noticeable effects.
I'd check with a pressure gauge taped to the windshield before replacing parts. But, I'd check with the gauge before doing the fuel filter also... that would rule out the filter, the pump, the pickup sock and the pressure regulator.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #4 (permalink)
Old 08-21-2004, 09:11 AM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
I concur, that sounds like the symptoms associated with a clogged fuel filter. It is cheap and easy to replace on a Ranger, and as it sounds like you've tried just about everything else, I'm almost willing to bet that's where the problem lies.
Bart
  #5 (permalink)
Old 08-22-2004, 06:39 PM
Changed the fuel filter and checked the fuel pressure. OK there. Still dies only under wide open throttle. Dealford may have something I can check out...
  #6 (permalink)
Old 08-24-2004, 06:04 AM
The hesitation solution...
The problem turned out to be the mass airflow sensor. Was sensing wrong forcing to much fuel at wide open throttle killing engine.
Tags
1994, 2002, 23, ac, distrubition, ford, full, hesitation, power, problems, ranger, throttle, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
