Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-18-2004, 03:21 PM
1952henry's Avatar
1952henry 1952henry is offline
Garage is empty, add now
1952henry is gaining momentum as a positive member of FTE.
oil filter lines
Please check my correctness. The bottom of the oil filter fits into the passage above the oil pan on the left side of the block, and the top of the filter fits into a tee with the sender unit. Am I right or not?
Thanks
  #2 (permalink)
Old 08-18-2004, 07:17 PM
Overkill-F1's Avatar
Overkill-F1 Overkill-F1 is offline
Overkill-F1 is starting off with a positive reputation.
You have it right, be sure that there is a restrictor inline for the input of the oil filter. ...Terry
__________________
It is a simple task to make things complex,
but a complex task to make them simple.
  #3 (permalink)
Old 08-18-2004, 11:10 PM
1952henry's Avatar
Why, what kind?
  #4 (permalink)
Old 08-19-2004, 12:24 AM
One of the fittings will have a smaller opening thru it, it will restrict the flow of oil to the bypass filter. Only part of the oil will flow thru the filter. This is normal operation, if the restrictor is not in place, your oil pressure to the rest of the engine will be low or non-existent. ...Terry
__________________
Tags
filter, flathead, ford, lines, oil
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
