1987 Ford Ranger 2.9L V6 specs!?
The 1987 2.9 V6 was rated at 140 HP @ 4600 RPM and 170 ft. lbs. of torque @ 2600 RPM. It has a bore of 3.66 inches and a stroke of 2.83 inches. It is a 177 CID engine. In '87, it had a compression ration of 9:1. The firing order is 1-4-2-5-3-6. It was timed at 10 degrees BTDC. I hope that helps you out some!
Are the specs the same for 89 ranger 2.9l ? Thanks
Just wondering if the specs are the same for the 89 ranger 2.9l
