No start=Faulty EEC?
08-17-2004, 10:46 PM
on
My wife's uncle has a 1982 Bronco that cranks but no start. It literally ran perfect one day and the next day it would not start. There is no voltage at the coil wire. We did check all primary/secondary ignition parts and voltage, all test good. This is the first year for computer controlled ignition. The only items it has that we know of is a CPS, which we also replaced (no help) and the computer under the driver seat. We are thinking that is the problem but Ford says it is discontinued? Any idea's are greatly appreciated.
Brian
08-18-2004, 09:34 AM
so there is no voltage going to the coil. have you replaced the solenoid located on the fender. they go out alot.
08-18-2004, 09:49 AM
on
What solenoid are you referring to? We replaced the ignition module on the Left fender, that didn't help. Someone had mentioned checking a ballist resisitor, but we could not find it in any of the manuals we have.
08-18-2004, 09:50 AM
thats the solenoid i was talking about. did you hook it up correctly? and trace the wires to the coil.
08-18-2004, 12:27 PM
on
The ignition module was replaced with a known good one. The hookups are idiot proof. All wiring to coil was checked with volt meter. All within spec.
Brian Fulcher
04-26-2015 10:19 PM
MC5C
07-05-2012 08:39 PM
93 stacked f250
06-06-2010 09:11 PM
*2fords*
06-16-2009 09:25 PM
Brian460
1999 to 2016 Super Duty
10-02-2005 07:45 PM
