driveshaft angle?
driveshaft angle?
How much downard angle from the tranny to the rear end is acceptable? Since the only way to alter this is to lower the trans and change the angle at which the engine is setting is this something I shoud be concerned about? It just seems a little too much (351W to an aod ) Thanks for any comments
1-3* is minimum. You need some off-set so the u-joints get lubed. If I remember right 5-6* is normal. U-joints fail very rapidly at 13*
How much are you talking about? You've got a bit of range to work with.
Just make sure the pinion is "opposite but equal" so the crank and pinion are parallel.
I think there's a tech post over on the right side of the page regarding driveline setups.
on
driveshaft phasing
maybe this will help a little... MT gave you good info
http://www.clubfte.com/users/jniolon...nephasing.html
later
John
later
John
