534 Engine Swap
Old 08-02-2010, 10:16 AM
RyCoy's Avatar
RyCoy
RyCoy is offline
534 Engine Swap
I have been tossing around the idea of re-powering my 1962 C1100 Fire Truck. with a diesel. Seeing as how I had a fairly major failure of the current 534 yesterday, that idea is now looking like a very possible option. I have read numerous posts talking about swapping to a 3208 or similar cat, but how much would be involved in the end. Will the 5 speed currently in the truck mate up to the cat or will there need to be a lot of fabrication.
Will I need to change the transmission and/or rear end to accommodate the different rpm power range of the diesel.
Any help would be greatly appreciated.
Ryan
Old 08-02-2010, 06:52 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
534 used an SAE pattern bell, if what I've read here is correct. The Cat engine would do likewise.
Ratios? The 534 was good for what, 3400 rpm? It probably "cruised" at 2000-2500? Where is the Cat happy?
This would be a fair amount of work, with fuel system and accessory drives part of the little things after mounts and trans adaptation. Regearing could be a deal breaker. Perhaps a different trans with OD ratios would be a better thing to research.
I take it this is a hobby truck and they're not waiting for you out on the fire line, so look long and hard, make lists, check 'em twice.
Check this site. You may still go Cat, but you may get some ideas looking at their kits etc.
fordcummins.com - Increase Horsepower with Ford Cummins Diesel conversion kits
6t56
401, 477, & 534 SD Engines
06-09-2020 03:31 PM
BiGGreen350
Ford Truck Parts for Sale
79
10-25-2014 05:48 PM
lrd56
18
04-28-2011 03:49 PM
northern 7.3
15
01-15-2010 09:01 PM
mrautocar
04-14-2007 10:49 AM
Quick Reply: 534 Engine Swap
