san antonio
You will need to use a breaker bar (or a cheater pipe on your wrench) and hold the flywheel. I usually use a pair of vise grips on the ring gear to keep the flywheel from turning. But if you rotate the engine so that the bolt you are loosening is at 3 o'clock and place the wrench at 9 o'clock, a quick yank down of the cheater pipe usually cracks the bolt loose. The bolts may be in with loctite and will be difficult if too much was used.
An impact would make quick work of the bolts but be sure to use an impact socked.
truckerboy
04-13-2010 05:07 PM
