Rotating the pumpkin
Remember that when you rotate the axle to compensate for the pinion angle, you will affect the caster which will make your truck drive like crap if you get in the negative range. Setting the driveline angle is a balance between setting the proper pinion angle and keeping wheel caster as close to factory spec as possible.
How you you plan to rotate the axle? I use adjustable upper and lower control arms on my coil sprung front axle.
hmmm, well that should be interesting! never heard of anyone doing that before so i dunno! i say if you have done knuckles before and you fell confident enough then go ahead!i won't ever be doing it....so i may call you!
as long as the oil wells on the bottom can still hold the diff fluid and you aren't messing with caster i don't see a problem! just make sure to weld it right the first time!
-cutts-
-cutts-
I've never done it but have seen it done or rather the finished product, and it doesn't look to difficult, now I have narrowed 9in housings, and I don't imagine it is much different with the exception of they don't use the weld plug but instead a round weld, one thing though the axle tubes are pressed in on a Dana axle then welded so even after you cut the weld out you will stillhave to press the axle tube out, and back in, biggest thing is make sure they are straight when we did 9in housings we used a laser level shooting it through the housing at all sides to make sure everything was straight before, and after welding.
It may sound crazy, but I'm going with hoxii. I cut my tubes on my D60 front after failing to remove enough metal from the knuckles to spin them. After cutting them I placed a sleave on the outside of the tube and welded the tubes themselves and ground them down and slid the sleave over and welded them. My truck is offroad only but I beat it's *** pleanty, tires in the air and all and no problems. Good luck with whatever you do.
RubberDuck
RubberDuck
The truck is lifted 8". Its a 1/2 ton 76 stepside with custom drop brackets for the arms. cutting the knuckles would include re-doing the drop arm brackets, making custom coil perches ...then caster to worry about. Im thinking im up to a new challenge on turning the pumkin. I considered cutting my tubes and making sleeves...but you loose strength!!! Dont you?
Procedure : Remove the front end
Drill out the plugs
Re-install the front end
Use a hydrolic jack to lift up on the tip of the pumpkin to rotate into place
Tack weld
Remove the front end and weld up
Thoughts?
Drill out the plugs
Tack weld
Thoughts?
Originally Posted by proeliator
Yes. But a heavy enough sleeve properly welded on and it would not be a huge compromise. Heck, you could cut it, sleeve it, and incorporate the sleeves into a truss and it would be stronger than before. There is nothing wrong with your plan other than it is a major, major pita to do, especially right.
