I'm looking to order a 2005 250 with a v-10 ,automatic and wanted to get 3.73 limited slip. My dealer tells me it's not available, I need to go with a 4.10. Is he correct?
At the Edmonds or the ford web site you can build it your way with all available options and a drop down that is good for telling what is included in different packages. I believe that the 3.73 are available in both open and LS. Of course that will only show you the possibilities not what is currently on hold due to supply problems. I have not heard of any shortages on diffs, just 18 inch wheels and the brake controller and mosdt of those problems are clearing up.
John looking at the specs that Jeff sent me a while ago it doesn't look like the 3.73LS is an option for the V10, you can get the 4.10LS or the 4.30LS however.
