Purchasing a used F150 or F250
Hello all - I am looking for a used F150 or F250, from 1987 to about 1993 or 1994. Besides the usual caveats when buying used, is there anything peculiar to these vehicles that I should watch out for?
For example, if I knew that someone was considering a 1991 Taurus, I'd warn them about the transmission problems these cars have. (I personally know one guy with a '91 Taurus that has 120K miles and is on its 4th transmission. Why he doesn't get rid of it I don't know, but I am getting off the subject). What I want to know is if trucks of this era have any Achille's heels that I should watch for.
I'm one of probably three people living in central Washington state who do not own a boat or 5th wheel, so I don't have anything to tow. However, it would be nice to have the capability to tow something if I need to.
I'll use the truck to haul large items that won't fit in my Explorer, or messy things that I wouldn't want to put in my Explorer (such as bark, fertilizer, gravel). As it wouldn't be my daily driver, fuel economy is not a concern (I only live 3 miles from work anyway). And I don't need 4wd, as my Explorer has that. I do, however, want an extended cab and an extended bed, and it must have air conditioning. It can get up to 115F in the summer here, and hey - I like to be comfortable!
Any advice will be greatly appreciated. Thanks in advance!!
Kevin
Kevin
Go to the towing forum for some recent interesting posts on gross vehicle weight ratings and how truck style and size will affect how much you can load and/or tow within limits. Also, the tech section has (I think) a transmission identification guide.
Don't trust a Ford dealer to be truthful on this. Look yourself at the owners manuals under Loads or Towing to find tables which will show what you can load and/or tow based on what model truck, engine, rearend ratio, moon alignment, and hair color. sorry, got carried away.
Check with your Explorer manual as well...you might find you'll be better off buying a used Big Tex hydraulic dump bed trailer for less than a truck might cost. No extra insurance cost either.
IF you're looking at auto trans you will want to familiarize yourself with which trans's were in which years and how to tell the difference between the AOD and EAOD. The latter is the stronger, but it's computerized. I just spent $1700 getting my AOD rebuilt after 128K (I bought the truck at 100k). Three trans shops swore my 93 f150 4x4 would have an EAOD...but I must've got some kind of orphan truck.
Essentially, I wouldn't buy a used truck of that vintage again unless it had a recent rebuilt trans or I got a steal of a deal. My trans guy told me the stock AOD's last an avg of 130000.
good luck,
Erik
good luck,
Erik
The 87-96 trucks have no major mechanical defects to watch out for (no busting trannys or blown motors). All 3 engines have their respective place, all great engines. If you're looking into just a utility truck, I would also consider the trailer like the others suggested. It's easier to load/unload a trailer (dump feature/lower) than it is on a truck.
The fuel tank issue is no big deal, the trucks do all have their own little quirks but what vehicle doesn't. Watch out for rust in the wheel wells and around the bottom edges...those are the first places to rust. Just try to find one that's in good shape and you'll be satisfied with one
Well, I'd love to go out and buy a new 2005 F150, but I don't want to make payments. You can probably afford a 2nd vehicle if you buy used, especially if you do most of your own repair work, like I do. I've been doing probably 90% of the work on my vehicles since I was 16 (I'm almost 46 now), and over the years, I'm sure that I've saved enough to buy that new truck. But I'm also cheap, and just can't see dropping $30K or more on one vehicle. But it sure is tempting.....
cjben
01-27-2016 03:15 PM
jjoel
05-18-2005 11:17 PM
