1950 F1 front leaf springs on a 1950 F3
Anybody done this? While working on the brakes of the F3 I found the drivers side main leaf broken. I have an F-1 for pieces and the leafs look fine. They appear to be the same size width wise just a little thinner. How many leafes are in a leaf pack from the factory? Might be a good time to remove a few while changing the leafs over to the other truck. The F-1 springs have three redeeming qualities
- They are paid for
- They are not broken
- They probably would give a better ride including height the are thinner. It looks like it would drop the front of the truck about an 1".
on
I have F-1 springs on my '51 M-3. They bolted on without a problem. They are basically identical but drop the front end like 1-1.5". I was in the same problem as you since one of the M-3 springs was broken and didn't match the other. You only lose like 500 lbs capacity in the front. I also use the rear springs also but this requires relocating spring hangers. I made a template from the F-1 frame and drilled new holes in the M-3 frame. I also took the rear spring hangers from the F-1 which bolted right on. I kept the entire spring pack together because the 8 foot box weighs in at 500 lbs! which is alot heavier than the F-1 box. I did submit a tech article on installing F-1 springs and rearend in a F-2/3 and M-3. In my gallery 1st '51 Mercury M-3 shows the frame.
NotMatt
09-19-2016 07:30 PM
1950 79 ford
08-12-2012 10:06 PM
TJDave
02-08-2011 04:09 PM
clhart426
09-17-2010 06:30 PM
