401, 477, and 534 new to me?
Old 08-26-2004, 04:24 PM
TheNomad's Avatar
TheNomad
TheNomad is offline
Hiya every one.. Ok i'm kinda a newbie here I didnt know Ford makes Engines that big... I thought the 460 was the bigist they made.... do they still make the motors or did they go the way of the Dodo? And are these engine only SD. or could you put one of those beast in a normal truck?
I know GM is making a 502 Why cant you put a 534 in a car or truck?
Old 08-27-2004, 12:23 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
Read thru the posts here. The 401 to 534 were late 50's designed monster gas motors. Way to heavy for a car, don't rev, have serious design issues that prevent hi po tuning. These were slow turning truck and industrial engines. Some found their way into boats, where they worked just fine.
These have gone the way of the do do, replaced by the 429 truck motor and oil burners.
Old 08-28-2004, 11:50 PM
ML1983's Avatar
ML1983
ML1983 is offline
These engines existed from about 1958 to 1983. They were only found in Ford's heaviest truck applications (Caovers, etc.). As was just said, these engines were low-reving very heavy designs built during an era when diesel engines weren't as capable as they are today. They were largely replaced by diesel engines in the 1980s.
Old 09-24-2004, 09:51 PM
Loan Ranger's Avatar
Loan Ranger
Loan Ranger is offline
Besides being quite heavy, the SD's also had offset fan and water pump pulleys for various chassis applications. With their height from oil pan to oil-bath air cleaner, width from exhaust manifold to exhaust manifold, and length from water pump pulley/cooling fan to bellhousing, it would be pretty tough to fit one in a LD truck frame.
Too, getting a radiator big enough to cool the beast on the street and getting that under the hood of a LD truck would be a chore.
Wouldn't the EPA have a brick trying to inspect one of THOSE, though?? LOL
6t56
401, 477, & 534 SD Engines
06-09-2020 03:31 PM
1976C900FireTruck
Large Truck
02-18-2010 12:36 PM
emeril
11-02-2009 05:56 PM
less
04-09-2008 03:39 PM
tomk89xlt
40
05-06-2002 11:11 PM
Quick Reply: 401, 477, and 534 new to me?
