Hood upgraded
Hood upgraded
I'd double check on where those mount on the hood. We've got a pretty flimsy hood. I'd to see those installed only to have the mount area warp/strip after a year or so. I travel a two line highway at 70mph and see alot of rocking in the hood when I catch the wind off a large truck from the opposite direction. Last spring the hood opened to the point that the secondary release was all that saved it from fully opening and slamming into the windshield/cab. I'd just worry if they aren't designed to allow some rocking without putting stress on the mounts.
I got this reply from the manufacturer:
"Attaching our hood QuickLIFT has zero effect on anything, other than opening the hood. The hood latch in the front of the vehicle is designed to grab, hold and latch the hood. Our QuickLIFT has zero affect on the latching operation. We are replacing the prop rod with gas springs, just as many vehicles have included stock from the factory. This whole assembly and kit cannot affect hood closing or latching, that is not possible. The whole kit is designed to tuck up nicely when the hood closes.
Please note the following information and post where necessary - others are incorrect.
If you have any other questions, please don't hesitate to ask.
Brian
Redline Tuning"
Brian
Redline Tuning"
Originally Posted by buzo-ech
"Please note the following information and post where necessary - others are incorrect.
While I like my Escape, the last vehicle I owned with such thin sheet metal AND a hood that can rock/lift/wobble due to the wind from vehicles coming in the opposite direction was a 77 Datsun. Eventually the hood supports gave way at the tack welds due to the movement.
The struts may be just fine. Just something to watch for if you drive a lot of highway miles.
Major Marvin
19
02-10-2011 07:10 PM
jake00
General Automotive Discussion
41
09-25-2006 10:28 PM
n0esc
11-04-2003 06:06 PM
