how much hp does my 351W have before and after all of my mods!
I have a 1981 351W it was a 2brl to start with and it came out of a f150! Here is a list of all of the upgrades I put a set of ported and polished heads with the large valves 1.64 and 1.90 ,BBK 1 7/8 headers,roller rockers, edelbrock rpm intake,eldelbrock 600cfm 4brl carb performer rpm cam, accel super coil, accel 300+ wires and plugs, msd distributor, and a high volume oil pump! I would love to know a good ball park figure I would guess around 300hp or so what do you think!
I can only venture a guess, based on published fiugures of similarly built Ford crate 351 engines.
The Ford 351 HO SVO made 385 HP at 5750 rpm and 377ft-lbs of tourqe at 4500 rpm. This motor used Aluminum Turbo Swirl heads, and a very stout cam, so yours will probably be somewhat less, with peak hP coming at a lower RPM.
The 351 GT40 SVO motor used cast iron GT40 heads and a cam fairly close to the Edelbrock RPM. This motor made 346Hp at 5750 rpm, and 364 ft-lbs of tourqe, at 4250 RPM. Depending on the quality of the porting job, your heads may flow slightly better than un-ported cast GT40's.
The stock 351 Lighting short block using un-ported cast GT40's, and the GT40/Cobra EFI induction parts made 310 HP.
ftrk66
17
03-24-2014 08:16 AM
GrossPapi
08-24-2013 11:48 PM
webster
10-30-2012 02:28 PM
