Go Back   Ford Truck Enthusiasts Forums > General > General Automotive Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 08-12-2004, 11:20 PM
Boss_358's Avatar
Boss_358 Boss_358 is offline
Boss_358 is starting off with a positive reputation.
Need help with my ZX2 belt routing
Well as the thread title says I need a little help with some serpentine belt routing. I had to put a new alternator in my 99 ZX2 and have completely lost the routing for the belt. Does anyone have a diagram or know where I can find one on the web. I thought there is usually one under the hood somewhere but there isn't in this case. The owners manual shows nothing and the Haynes manual has been pretty much wothless through out this task. I wish I had a chiltons for this thing too. Also, I forgot to unhook the battery before I started and when I was disconnecting the alternator wire I think I popped the main 100 amp fuse under the hood. Anyone happen to know how these fuses come out? Manual says there is a screw holding the main one in but I figure I would ask while I am at it. I have never had to deal with these types of fuses before so I don't want to break anything. Thanks!
__________________
"Tyranny is defined as that which is legal for the government but illegal for the citizenry." - Thomas Jefferson
  #2 (permalink)
Old 08-13-2004, 01:29 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold
Man I hate putting belts on those things. Oh well.
I dont know which type of fuse you have. The Maxi fuses just pull right out. I think that some of the other big ones have nuts on the bottom side but I cant find it in tha manual. You might have to lift up the fuse box to look.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #3 (permalink)
Old 08-13-2004, 01:49 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold
The section of the fuse box where those "bolt-in" fuses are should unclip. You should be able to lift that fuse assy just enuf to reach in and loosen the screws. The first time I ran across those in a Contour I tried to just pull the fuses like any other fuse... -OOOooops
ALWAYS pull the neg battery cable when working on vehicles!
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #4 (permalink)
Old 08-13-2004, 11:29 AM
Boss_358's Avatar
Thanks Dave! With that diagram I had that belt back on within a couple of minutes. I was close, but had the belt going around a couple of pulleys wrong that gave me too much slack. As far as the fuse goes, it has two little bolts that take a 10mm wrench. one is visible to the front of the car, the other has a cap over it on the other side. I don't think the belt was anywhere as near as bad with the correct routing as swapping that alternator was. Its things like this to why we waited until just recently to buy a front wheel drive car. Of course its only our second with all of the electronic gizmos. The other is our Ranger and that is still new enough to where all it needs are normal routine maintenence.
__________________
  #5 (permalink)
Old 08-03-2007, 08:27 PM
busman523 busman523 is offline
busman523 is starting off with a positive reputation.
Ford ZX2 Escort bely routing diagram
New member. Racerguy posted a diagram/photo on the 2.0 liter Ford ZX2 Escort belt routing. It shows numbers. Could you tell me which numbered item is the tensioner? I need to change the belt on my wife's car. Thanks for any help.
  #6 (permalink)
Old 08-03-2007, 09:14 PM
Racerguy's Avatar
Welcome to the forum busman
Number 4 is the tensioner.
__________________
Forum Guidelines
this space for rent
  #7 (permalink)
Old 08-03-2007, 10:05 PM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE. jimdandy has a good reputation on FTE. jimdandy has a good reputation on FTE.
You can usually figure it out if you remember smooth pullies go to the smooth side of the belt, and grooved pullies go to the groove side.
A simple test light will tell you if the fuses are good. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
  #8 (permalink)
Old 08-03-2007, 10:18 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of
You sure about that? Looks an awful lot like a water pump.........
Number five would be it.
__________________
Jared
The government said all my vehicle were too old to be clunkers
FTE Guidelines
  #9 (permalink)
Old 08-03-2007, 11:46 PM
Racerguy's Avatar
oooops I wasn't paying much attention....you're right
__________________
Forum Guidelines
this space for rent
  #10 (permalink)
Old 05-19-2008, 07:17 PM
wolf99bane wolf99bane is offline
wolf99bane is starting off with a positive reputation.
Thumbs up belt diagram for 2000 Escort ZX2
Hi,
New here and wanted to say thanks to whomever posted the diagram for the serpentine belt for my car. I searched the net over and finally lucked up here.
Thanks Again,
Vickie
  #11 (permalink)
Old 09-19-2008, 10:30 PM
JL38606 JL38606 is offline
JL38606 is starting off with a positive reputation.
Hi, I had to sign up in order to thank the person who put the diagram on here it was a big help, keep up the good work and thanks again!!
  #12 (permalink)
Old 10-05-2008, 05:14 PM
izziebeano izziebeano is offline
izziebeano is starting off with a positive reputation.
Smile diagram
Ok. I can't find a repair manual for my Ford 2002 Zx2. Thanks so much for the diagram of the serpentine routing diagram. Needed it! Where can I find diagrams &/or repair manual for future needs? Thanks!
  #13 (permalink)
Old 10-05-2008, 05:21 PM
Racerguy's Avatar
You're welcome
You can find used manuals on CD or DVD on eBay.
Sometimes people also sell paper manuals there too but they go for quite a bit more money.
You can buy new manuals and online manual subscriptions at www.helminc.com
__________________
Forum Guidelines
this space for rent
  #14 (permalink)
Old 10-30-2009, 02:52 PM
FordGirl1961 FordGirl1961 is offline
FordGirl1961 is starting off with a positive reputation.
Talking saved my butt
hey guys thank so much for posting everything you did. i grew up around fords and my whole family are mechanics. but when i moved to denver i was on my own. and then i had to replace a belt all by myself. thanks for the diagram and the placement of the tension pully. helped so much
  #15 (permalink)
Old 10-30-2009, 06:28 PM
Racerguy's Avatar
Welcome to the forum Fordgirl1961
If you have any other Ford related problems you will probably find someone on there that can help, if you don't want to ask your family.
__________________
Forum Guidelines
this space for rent
Tags
2000 , 2002 , 2003 , belt , diagram , drive , escort , ford , fuse , maxi , pull , route , routing , serp , serpentine , wheel , zx2
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
