How do you replace the turn signal bulb in a 1996 - Ford Truck Enthusiasts Forums
Old 05-08-2001, 04:56 PM
boss3024me boss3024me is offline
boss3024me is starting off with a positive reputation.
OK I give up how do you get to the turn signal parking light bulb in the front of a 1996 explorer ????
Paul
Old 05-08-2001, 10:57 PM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
If there are no external screws to remove from the parking light lens then it is held on by bolts accessible from behind the lens. Once the screws , bolts are removed the lens should pull out & then its just a matter of twisting the bulb socket & pulling it out of the lens , replace the bulb .
Old 05-09-2001, 10:56 AM
patentguy patentguy is offline
patentguy is starting off with a positive reputation.
Front turn signal bulb replacement harley3348 1999 to 2016 Super Duty 3 02-21-2011 12:08 PM
92 Front marker light.... arrrrrhh, bulb change Turx 1987 - 1996 F150 & Larger F-Series Trucks 2 02-17-2011 07:12 PM
How to change front turn signal bulb? CruiserClass 1999 to 2016 Super Duty 9 03-01-2007 12:57 AM
How do I replace bulb in 2001 Expidition signal mirror. tactsarge Electrical Systems/Wiring 1 05-15-2004 08:38 PM
how to change front turn signal light bulb rsimmer1 1987 - 1996 F150 & Larger F-Series Trucks 1 03-06-2003 05:29 PM
Tags
1994, 1996, 2006, 96, bulb, change, exploer, explorer, explorere, f150, ford, replacing, signal, signals, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
