Iowa Chapter Join Chapter, Leader:
OBD-II Code Reading needed in or around Ames, IA
Old 08-11-2004, 02:01 PM
Claus's Avatar
Claus
Claus is offline
I'm going to try my luck. Do you or somebody you know have an OBD-II code reader? The ABS light of my 2003 Explorer comes on sometimes and I would like to pull the code to start trouble shooting. I wouldn't mind giving a little money for it. I'm located in Ames, IA and would consider somebody close by especially since I can't garantee that the light is on at any specific time.
Otherwise, recomendations for PC scan tools that can read ABS codes are welcome as well.
Old 08-28-2004, 01:59 PM
fellro86's Avatar
fellro86
fellro86 is offline
Did you ever get this taken care of? Autozone offers code reading as a service, but I personally won't buy any electrical parts from them unless I'm desparate. Otherwise, you may be able to get a reader that only tells codes, and then come back to FTE to figure out what to do.
Old 08-29-2004, 12:18 AM
Claus's Avatar
Claus
Claus is offline
Yes, it's taken care off. I've taken the bullet and went to the dealership. It was the rear ABS sensor that needed to be replaced.
BTW Autozone does not pull ABS codes. I guess a generic OBD-II code reader can't read ABS codes. Bummer.
Old 08-29-2004, 10:18 AM
fellro86's Avatar
fellro86
fellro86 is offline
Good to know... Glad you got it taken care of, too bad had to be at that cost. If you had been in Cedar Rapids area could have helped you out.
lemonshindig
05-23-2014 06:49 PM
KG Excursion
Modular V10 (6.8l)
13
05-09-2014 01:13 PM
powersmoked
1983 - 2012 Ranger & B-Series
03-13-2012 08:51 AM
Jaime74656
17
12-26-2011 08:09 AM
Quick Reply: OBD-II Code Reading needed in or around Ames, IA
