Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Iowa Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
  #1 (permalink)
Old 08-11-2004, 02:01 PM
Claus Claus is offline
Garage is empty, add now
Claus is starting off with a positive reputation.
OBD-II Code Reading needed in or around Ames, IA
I'm going to try my luck. Do you or somebody you know have an OBD-II code reader? The ABS light of my 2003 Explorer comes on sometimes and I would like to pull the code to start trouble shooting. I wouldn't mind giving a little money for it. I'm located in Ames, IA and would consider somebody close by especially since I can't garantee that the light is on at any specific time.
Otherwise, recomendations for PC scan tools that can read ABS codes are welcome as well.
  #2 (permalink)
Old 08-28-2004, 01:59 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Did you ever get this taken care of? Autozone offers code reading as a service, but I personally won't buy any electrical parts from them unless I'm desparate. Otherwise, you may be able to get a reader that only tells codes, and then come back to FTE to figure out what to do.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #3 (permalink)
Old 08-29-2004, 12:18 AM
Quote:
Yes, it's taken care off. I've taken the bullet and went to the dealership. It was the rear ABS sensor that needed to be replaced.
BTW Autozone does not pull ABS codes. I guess a generic OBD-II code reader can't read ABS codes. Bummer.
  #4 (permalink)
Old 08-29-2004, 10:18 AM
fellro86's Avatar
1978 Ford F-150
Good to know... Glad you got it taken care of, too bad had to be at that cost. If you had been in Cedar Rapids area could have helped you out.
__________________
Tags
ames, code, codes, ford, ia, obd, readers, reading, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
