Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-10-2004, 05:13 PM
79F150-400 79F150-400 is offline
Garage is empty, add now
79F150-400 is starting off with a positive reputation.
94 four banger?
Im thinking of buying a 94 ranger 2 wheel drive 4 cyl five speed, the engine has a dead cyl and supposidly a coil pack was changed and it didn't fix it I was just wondering if there are any reoccuring problems that someone might know about any help would be good also is there anything else on the truck that I need to check out before I would purchase it thank you very much
  #2 (permalink)
Old 08-11-2004, 08:44 AM
Vin 95 Vin 95 is offline
Vin 95 is starting off with a positive reputation.
Try listing this thread in the ranger forum,you'll probably get a faster response.
  #3 (permalink)
Old 08-23-2004, 08:03 AM
StockRanger StockRanger is offline
StockRanger is starting off with a positive reputation.
Check your wires to make sure the charge is getting to the plug. It's probably either a connection or, if the wires have never been changed, a bad wire. Pull the plugs to make sure they are in good condition. If all that checks out OK, then you have to look internally to the engine (check cylinder compression, valvetrain, etc.). Good luck.
__________________
'94 Ranger XLT SC. 2.3L 5-spd manual 4X2. modified civic air intake, custom Dynomax cat back dumped at rear axle. Up next, Diablo chip & underdrive pulley.
Tags
ford, fourbanger, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
