i junked my 86 f250 .it has a 300/6/t18 4 speed.im going to put it in my 71 f250 .how big a clutch will fit in the bellhousing.the bellhousing is a 71 from a 240.i traded the 390 for all the manual clutch parts.
thank you
lrd56 a happy dinosaur
Hey, I have been looking into that for down the road. Does the starter have to be changed, or does it use the same ring gear on the flywheel? If all you have to change is the flywheel and clutch, should be a fairly cheap and easy upgrade. Ted
I used the same starter. the flywheels were the same except for the pressure plate bolt holes. I swapped from 240 to 300 6 cyl. and installed t-18 trans from a 73 FE truck
