What engine can i fit in a '89 F150? - Ford Truck Enthusiasts Forums
Old 08-10-2004, 01:18 AM
mxkris mxkris is offline
mxkris is starting off with a positive reputation.
Question What engine can i fit in a '89 F150?
What kind of engine could I fit in my 89 f150? How big could i go? What's reasonably priced, easy to install, but still powerful?
Old 08-10-2004, 01:33 AM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
you could put a 460 in there, it's the same exact body as an F250 and F350.
Old 08-10-2004, 11:13 AM
ok...what would you put in there? do you have any idea on how engines are priced? where could i find out?
Old 08-13-2004, 02:40 AM
drewcoolness99's Avatar
drewcoolness99 drewcoolness99 is offline
drewcoolness99 is starting off with a positive reputation.
if it was me i would go with a 351 that way i could keep it efi(assuming you have a 5.0) so it would be easy to do. you could go over to carb so you don't have to deal with the limitation of speed density though. a 351 built right can put out some horsepower. if you want a power house then you could go with a 460 and just upgrade the front suspension, to compensate for the added weight.
Old 08-13-2004, 01:07 PM
A 351 sounds good. I'm not looking for something so huge I need to beef up the suspension alot, but thanks for that info. How do I go about finding out about retail on an engine and where to get it? What should I look for? Thanks for putting up with my stupidity when it comes to this stuff.
Old 08-13-2004, 01:10 PM
we all gotta learn somehow. Check aroudn for engine suppliers in your area. Check your local chapteer of fte and see if they can reccomend any good places.
Old 08-13-2004, 01:11 PM
ok. thanks alot
Engine Swap 89_Bronco_lover 1978 - 1996 Big Bronco 4 05-06-2015 05:14 PM
will it fit? 1989lariat Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 12-30-2014 03:56 PM
89 brake booster, will it fit a 84? craftsmangary 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-27-2014 10:23 PM
89 truck 99 motor DGHenin 1987 - 1996 F150 & Larger F-Series Trucks 10 03-25-2014 08:33 AM
95 cab and engine swap onto an 89 frame and tranny (clutch problems) Marteney 1987 - 1996 F150 & Larger F-Series Trucks 6 01-05-2014 02:33 PM
Tags
1989, 460, 89, engine, engines, f150, f350, fit, kinds, motor, motors, put
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
