Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
Georgia BBQ
Old 11-09-2008, 12:00 AM
old87's Avatar
old87
old87 is offline
Donnie, the doctor is here tonight, he said, "i had to check the valve clearance on the #5&7 cylinders due to a horrendous knocking. sounded like a "midget with a sledge hammer trying to get out," and all seemed to be well. found out that it was nothing but a lifter that had lost pressure and was causing a bad valve rattle. in test driving the truck, we also discovered that it was in dire need of a high volume oil pump and larger pan to keep valve float from occurring at high rpm. this being said the motor for the beast is coming together in the form of a nasty 545ci big block. bore is going to be 4.390in which as everyone knows is only a .030 overbore on factory. the stroke is going to be 4.500in which is a full 1/2in over stock. rod and main journals will remain the same size, but the rods will have to be "H" beam form to make them as strong as possible in size 6.700in to make up for the longer stroke. Pistons are forged ross parts with a small dish. Edelbrock performer rpm heads with a 95cc combustion chamber will leave me with a compression ratio of 10.5:1. With all the parts that i am figuring, this motor will push around 550hp, and around 650ft/lb torque on pump gas. all of this on top of the 150 shot of NOS this should make for one wild ride. dont feel like getting into cam specs and flow charts on the heads right now, considering the heads are ported above out of the box specs, but feel free to call me or email me to get more details. The doctor is always on call for emergency calls, and last minute have to get done surgeries. all requests for service should be presented in writing, and most major insurance is accepted. You know how to contact me in need of assistance, and house calls."
anyhow thats what he said.
good ain't he....
  #1142
Old 11-09-2008, 01:00 AM
old87's Avatar
old87
old87 is offline
P.S. the doctor said, "WE HAD SQUEASAL AND IT WAS GOOD!"
  #1143
Old 11-09-2008, 01:03 AM
old87's Avatar
old87
old87 is offline
"Cry,HAVOC, and let slip the dogs of war!"
Julius Cesar
  #1144
Old 11-12-2008, 06:45 PM
3broncocrazy's Avatar
3broncocrazy
3broncocrazy is offline
good ain't he....
Good, I'd say DAM GOOD Wish I could have been there!!!!!!!!!
  #1145
Old 11-15-2008, 12:25 AM
old87's Avatar
old87
old87 is offline
just hangin and jammin. yardbird fri and steaks sat nite. lotsa work done on the old87.
finally got a breather on five thru eight to releive some pressure but sure was a dog tryin to drill the valve cover with those plug wires in the way...
  #1146
Old 11-25-2008, 08:13 AM
3broncocrazy
Cool, old87 will be shakin' a VW windows again soon DW was over and we grilled pok-n chops......can't aford the steaks;-P will be able to if the gas prices stay down...The big D is workin on his ride, just turned 15 and learning to turn a wrench on it...DW is a mentor around here......
  #1147
Old 03-22-2010, 08:42 PM
captradiator's Avatar
captradiator
captradiator is offline
Well, it's about time we revived this thread!
Wife and I ate @ Blowin' Smoke in Savannah a couple of weeks ago. Pulled pork was good, as was the beef brisket. Hometown fav is still Sconyers.
Oh, had lunch @ Shealy's over in Carolina last week-good buffet.
  #1148
Old 03-26-2010, 02:34 PM
PhoenixRisen's Avatar
PhoenixRisen
PhoenixRisen is offline
Pit Boss on Virginia Ave. in Hapeville, Ga. He gives you some of the bark with it. Real pit too. Sauce is a matter of preference. Try it out. He also has a chunky Brunswick stew. Not that stuff you can suck up with a straw.
  #1149
Old 05-05-2010, 06:10 PM
Austin26372's Avatar
Austin26372
Austin26372 is offline
Pappy Red's in Cumming is good. Not the best, though.
  #1150
Old 05-05-2010, 07:58 PM
c125bob's Avatar
c125bob
c125bob is offline
X2 on Pit Boss. It's good stuff !!! Worth the drive, not fancy but damn good.
itsabullitt
Kansas Chapter
64
07-15-2016 07:29 AM
1950FordF1
06-01-2016 10:11 PM
LightningRyan
Ontario Chapter
09-28-2009 08:51 PM
Heavy"D"
Georgia Chapter
76
09-10-2007 07:24 AM
fordsrgrt
Iowa Chapter
07-11-2005 08:03 PM
Quick Reply: Georgia BBQ
