97 PSD died while Driving now won't start - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-06-2004, 07:52 PM
IdahoCowboy IdahoCowboy is offline
IdahoCowboy is starting off with a positive reputation.
Exclamation 97 PSD died while Driving now won't start
Hey everyone I'm a new member but a long time ford truck owner but this problem I am having is starting to get to me. I was driving down the road and all the sudden the truck went down to idle. I tried giving it gas but that just made it start to choke itself out or so it seemed so I just let it Idle and then it died. I tried to restart it but all it did is turn over. I had it towed home I check my fuel, fuel filter, oil,batteries,hooked up a OBD II computer scanner no faults manufacturers or generic I'm getting a reading on my tach as I try to start it so I don't think it is my Cam sensor so at this point I have exhausted my knowledge. I had a 91 Diesel and I knew it inside and out but this powerstoke is a whole different ball game. Thank for any help you all may be able to give
Old 08-06-2004, 08:02 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Lotta miles on the truck? I suspect a dead electric fuel pump going from what you are saying here.
Old 08-06-2004, 08:15 PM
the truck only has 162000 miles on it. the engine is a ford rebuild and was done 50,000 miles or so ago not to sure what the guy before me did w/ it. I check to see if I was getting fuel into the fuel filter bowl and it was pumping like normal
Old 08-06-2004, 09:27 PM
Monster350Ford Monster350Ford is offline
Monster350Ford is starting off with a positive reputation.
Chances are if your truck died going down the road it is your Cam/Crank position sensor. If it turns over fine and does everything normal accept for starting thats your problem. That sensor tells the computer where the motor is rotation wise and if it goes dead the truck wont know when to fire the injectors. Mine did the same thing, but I replaced it and everything has been fine. I was going down the road and it flat out shut off in the middle of the highway. I had the clutch in trying to start it again, but it wouldnt so I called the local high preformance diesel shop 1 mile up the road. They brought out the part, put it in and it cranked right up.
Old 08-06-2004, 09:46 PM
If this sounds like the same problem as your truck I guess I'll try the cam sensor probably is what is wrong anyone with any more advice???
Old 08-06-2004, 09:50 PM
STROKER350 STROKER350 is offline
STROKER350 is starting off with a positive reputation.
IdahoCowboy,
I had the same thing happen to me last summer in my 97 powerstroke. It was the cam sensor and the fuse to it. Dont get the sensor from Ford, go to an International Navistar parts place if you have one around there. Check the fuse in the fuseblock out under the hood over the drivers side wheelwell. Take the old blown fuse (if it is) with you so the parts people will know what size it is. Hopefully this will get you going again.
Stroker350
Mount Sidney, Virginia
Old 08-09-2004, 02:02 AM
Tommyquest Tommyquest is offline
Tommyquest is starting off with a positive reputation.
If the tach doesn't move when you try to crank it over, it's the Cam pos. Sensor
Old 08-09-2004, 09:04 PM
ok guys I have changed out mycam sensor and a couple fuses that I found that were blown but I still have nothing. It has plenty of power turning over, But I have noticed that it seems to shake alot as it is turning over the tach is reading fine just as before. Itested the battieries and they came out good. I am at a loss I was wondering if it my be the accelerator pedal sensor (or whatever its called) but I thought all that would do is make it Idle. thanks for any other help you guys may have...
Old 08-09-2004, 09:45 PM
IdahoCowboy,
I'll check with my friend, he's pretty good with the Powerstrokes. Did you check the oil? If it's too low, it won't start I've heard, I think it has something to do with the high pressure oil pump to run the injectors or something. Keep us informed, hopefully someone on here will figure it out for you. If I find out anything I'll let you know-I know it's a pain when something is wrong with the truck!
Rick
Old 08-09-2004, 09:55 PM
Thanks, yeah I have checked the oil and I changed it not to long ago but I am thinking about changing it again who knows it could be anyhting with this truck!!
thanks,
James
Old 08-09-2004, 10:15 PM
77hiboyboy's Avatar
77hiboyboy 77hiboyboy is offline
77hiboyboy is starting off with a positive reputation.
hmm confusing, but you are getting fuel for sure??
Old 08-09-2004, 10:17 PM
cookie88's Avatar
cookie88 cookie88 is online now
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Which fuses were blown? You need to check the oil level in the high pressure oil pump itself, not the oil pan. The small allen head plug on the drivers side top of the HPOP is where you check the level, it should be within 1" of completely full.
Old 08-10-2004, 12:41 AM
BCS_tx_dieselman BCS_tx_dieselman is offline
BCS_tx_dieselman is starting off with a positive reputation.
Old 08-12-2004, 08:08 PM
Is the allen plug on the pump a reverse thread or is mine just stuck anyone know??
also where do I plug in to check the oil pressure coming out of the pump?
Old 08-12-2004, 09:07 PM
78fordman's Avatar
78fordman 78fordman is offline
78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.
take a fuel pressure test and see what you have.
Truck Cranks but no start 1994 f150 Stratifiedjoe Ford Inline Six, 200, 250, 4.9L / 300 2 06-22-2016 02:06 AM
95 f350, 7.3.. Missfires and dies Anthony Bricker 1994.5 - 1997 7.3L Power Stroke Diesel 8 05-31-2016 11:08 AM
2002 5.4 f250 will start then dies! Brandon1153 1999 to 2016 Super Duty 6 05-07-2015 07:41 AM
vapor lock or fuel pump getting weak? CopenGrizz01 Ford Inline Six, 200, 250, 4.9L / 300 19 07-13-2012 12:59 PM
'76 F150 Engine Problems (Wants to Die) Deadkid9110 1973 - 1979 F-100 & Larger F-Series Trucks 13 06-02-2011 01:03 AM
Tags
02, 1997, 2001, 73, 97, 99, died, dies, driving, f150, idle, jetta, psd, start, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
