clunk in driveline
Old 08-06-2004, 06:03 PM
fordtruckfan90's Avatar
fordtruckfan90
fordtruckfan90 is offline
clunk in driveline
I own a 90 f-150 4x4 with e40d. The tranny has recently been rebuilt, and all u joints replaced. When the truck is driven for longer periods of time, and i come to a dead stop then take off, i hear a little clunk, more or less like something is moving underneath the truck that shouldnt, it goes and comes, but always when i have been driving for a while, i do know there is a little bit of play in the rear end, maybe noew rear end? I have the 8.8 w/3.55's, is that expensive, or another thing i heard was the t-case, i have the borg warner 1356, sould something be loose inside to cause this sound??
Old 08-06-2004, 06:05 PM
teds74ford's Avatar
teds74ford
teds74ford is offline
I would suggest something simpler. Your mounts. If it was out, and then put back in, it is possible that things have settled, and are now a little loose. Check the tranny mount, and the idler bearing mount if you have one. Ted
Old 08-06-2004, 08:45 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
Try removing the rear driveshaft and lubing the splines inside the slip yoke where it goes into the transfer case. Ford has Teflon grease for this but you can use any good quality grease. If it fixes it you have the choice of lubing it occasionally or replacing the slip yoke.
Old 08-07-2004, 04:24 PM
maa139's Avatar
maa139
maa139 is offline
Would wheel bearing or lithium grease work for this?
Old 08-07-2004, 04:59 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
I've seen people use many types of grease and they all seem to work.
mrad
06-13-2013 03:32 PM
bp460
1997 - 2003 F150
05-21-2006 11:45 PM
JC00EX
09-24-2003 11:11 PM
dbkc413
1983 - 2012 Ranger & B-Series
07-04-2001 06:01 PM
Quick Reply: clunk in driveline
