Towing Package Wiring
if you open the cover under the steering wheel(held on by 4 large plastic screws) and look to the right side of that opening you will see a black wiring plug behind that plug and through the metal bracket is a gray open plug with silver pins in it. that is where you plug in the pigtail that should have come with the truck. you also have to put in 2 relays in the under hood relay box (right next to the under "hood" fuse box) and install 2, 30 amp fuses in the under hood fuse box for it all to work
Originally Posted by pops_91710
this is my second prewired Ford tow vehicle and it's the first I have heard of any relays or fuses. I use a Tekonsha Prodigy. Doesn't need anything but the pigtail.
I am just getting my 2001 SD 250 ready to tow a trailer and found that I had to hunt down the 30 amp fuses that were installed in the wrong positions in the distribution box under the hood. Tow charge (# 16) fuse was in the shift on the fly feature (#17) that device is not installed on this truck and the other that feeds 12 volts to the electronic brake controller (#28) was found in the power seat adjustable pedals position (# 18) position, I don't have ajustable seats or pedals either. I had to purchase the 2 relays that go into the little piggy back relay box located under the hood near the power distribution box. So look around, you may have some spare parts stowed on your truck that can be used. I have a prodigy controller coming and also the Ford truck adapter cable that will plug into the wiring harness under the dash near the radio.
Okay, well that's weird. I was the first owner and I installed it. I did not use the pigtail provided by Ford I used one made for Ford supplied at extra cost from Tekonsha, I guess.
At any rate in the glove box was the trailer brake hook up only half of a harness with a clip at one end and nothing except cut aires on the other. The bag had no fuses or relays.
I have towed with it once in August of last year, also in May, and this July when I went on a 2,000 mile trip and it worked fine. I haven't towed yet with my new SD 4X4 V-10, so I want to be sure nothing's cookin' along those wires!!
I'll have to wait until I get home next week. I'm in Utah again but not in a Ford Truck....(Okay, it's a rice burner, but a darn nice one!! Accord EX).
The cable I purchased has a wrap around it as any other harness would. I wonder if the fuse is sealed under that in line from the factory??
I do remember the salesman during my new vehicle orientation session telling me that all I had to do was plug in the controller. I'll call him and ask them if they installed that stuff during intitial preparation prior to putting it out on the sales lot.
Yeah, I think they come that way. I e-mailed my uncle who worked at the Ford assembly plant and he says Ford has been doing this for many years. His '93 came with everything installed. Just plug n' play, so to speak.
Like I said, this is my third (not second) factory towing package. My '97 came the same way, just plug on the harness and the contoller.
I just purchased a 2003 F250 and it still had the pigtail in the glovebox, minus the fuses and directions. I found the connection under the dash as described above and wired my Prodigy box as detailed. Pulled my horses today and all worked as promised! I did find that my trailer had been wired differently and had to switch a couple of leads. The trailer sales dept. had wired my last truck to fit the trailor...a 5 min. fix.
Originally Posted by rockyrider
I had to order the little piggy back relay box located under the hood near the power distribution box, Never was installed from factory on my 97 F350 cost me $65 The only thing I need it for is trailer aux lights (exterior loading lights,interior lights)
