2000 Ford Ranger Fuel Pump Relay - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-06-2004, 11:43 AM
panton69 panton69 is offline
panton69 is starting off with a positive reputation.
I have a 2000 Ford Ranger w/ 3.0 V6. In the last couple of weeks it has started to have problems starting. Sometimes when I turn the Key the starter has to run a longer than usual before the Truck turns over. Like its not getting gas. I changed my plugs and wires and still have the problem. I would like to change out the fuel pump relay but do not know where it is. If there is anything else to check let me know Im hoping its not the pump. Some people have said to change the fuel filter but I have never had a fuel filter cause much problem in any vehicle. So if anyone has any suggestions Id appreciate it. Also if anyone could point me in the direction of a 2000 Ford Ranger Chilton Manual that would help as well I have been looking for a few years now.
Old 08-06-2004, 11:55 AM
wire4money wire4money is offline
wire4money is starting off with a positive reputation.
Does it start OK when warm? My Durango had a bad fuel pressure regulator. When it sat, the fuel would leak back into the tank, taking forever to fire. If I cycled the ignition on and off a few times, it would fire up instantly. As for the Chilton's, they are available. I also bought a Ford factory service manual on CD on EBAY for about $6.
Old 08-06-2004, 12:08 PM
Most of the time it does start better when it is warm but i have had a slight lag when it has been warm.
Old 08-06-2004, 01:05 PM
Vin 95 Vin 95 is offline
Vin 95 is starting off with a positive reputation.
There should be a diagram inside the cover of the under hood fuse box to show the location of the relay,when you have a no start situation, you might try tapping on it a few times,sometimes they stick when they get hot.but they are only $10.
Old 08-06-2004, 07:07 PM
Dave257 Dave257 is offline
Dave257 is starting off with a positive reputation.
You have some options, buy a fuel pressure guage and check for/eleminate proper fuel pressure, about $25.00.
Hope it is the filter and change it $10.00. Hope it is the relay and change it $20.00. Hope it is the fuel pump and change it $120.00.
If none of that fixes it. Buy a fuel pressure guage $25.00 and check for proper fuel pressure. If it is ok it is not related to fuel supply.
Dave
Strange Problems StangStang 1987 - 1996 F150 & Larger F-Series Trucks 2 08-23-2016 11:15 AM
Loses power climbing hills Surfcop Expedition & Navigator 13 04-09-2015 01:08 PM
1997 F53 Motorhome Fuel Pump Mystery Coverbrooke Fuel Injection, Carburetion & Fuel System 7 04-13-2012 07:54 AM
Gettin ready to throw in the towel HELP 5Rangers 1987 - 1996 F150 & Larger F-Series Trucks 4 07-25-2011 10:42 PM
Camshaft???? RANGER589 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 06-03-2011 11:03 AM
Tags
200, 2000, 2004, check, chilton, ford, fuel, fuse, location, manual, pump, ranger, rangter, relay, reset, switch, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
