Fuel Filter Replacement on 97 Explorer - Ford Truck Enthusiasts Forums
Old 09-29-2001, 05:29 PM
cotoole cotoole is offline
cotoole is starting off with a positive reputation.
Can someone please tell me what the trick is to get the fuel filter off the 97 Explorer? I purchased a replacement filter but I cannot get the origional off. Is there a trick to this?
Old 09-29-2001, 11:36 PM
knuckles knuckles is offline
knuckles is starting off with a positive reputation.
There's no trick, but you do need a special tool.
1. Remove the safety retainers from the fuel line/filter connections.
2. Install the special tool between the line & filter & slide it toward the filter to release the metal tangs that hold the line to the filter.
3. Slide the line off of the filter.
[a href="http://www.ontool.com"]Ontool.com[/a] sells a full set of Lisle brand fuel line tools for less than eight bucks. You should also be able to find them at nearly any local autoparts store. The Lisle set looks like this:
http://www.ontool.com/product/images/LIS/images/LIS_37000_fs.jpg
Old 09-30-2001, 10:35 PM
Ken2600 Ken2600 is offline
Ken2600 is starting off with a positive reputation.
97 front of motor fuel lines - Need some guidance nivrig 1994.5 - 1997 7.3L Power Stroke Diesel 4 04-28-2014 08:09 PM
Fuel Filter connector stuck hotwater6 1997 - 2003 F150 9 02-08-2013 08:18 PM
Fuel Filter replacement 92 F250 damons Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 30 04-27-2010 07:41 PM
fuel filter removal 98explorer Explorer, Sport Trac, Mountaineer & Aviator 10 07-15-2004 11:16 PM
changing fuel filter on 97 explorer briski04 Explorer, Sport Trac, Mountaineer & Aviator 6 04-04-2002 07:06 AM
Tags
1997, 97, explorer, explorerr, filter, ford, fuel, location, mountaineer, pictures, removal, replacement, special, tool, trick
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
