My version of the Exhaust brake mod. - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 10-16-2007, 12:22 AM
jhand124's Avatar
jhand124 jhand124 is offline
jhand124 has a very good reputation on FTE.jhand124 has a very good reputation on FTE.jhand124 has a very good reputation on FTE.jhand124 has a very good reputation on FTE.
If I have auto trans would purchasing the dfuser EBPV exhaust brake kit with TC lockup for $129+$59 for pig tail, be the way to go.
  #62
Old 06-20-2013, 10:42 PM
Squisher's Avatar
Squisher Squisher is offline
Squisher has a good reputation on FTE.Squisher has a good reputation on FTE.
I linked here from the tech sticky. I have a handshaker and was just wondering if the original post by kwikordead would still be considered a good route to go for an inexpensive exhaust brake. Just asking because no one has commented on it for a number of years.
My truck is a 550 4x4 and tows a dump trailer pretty well everyday.
  #63
Old 06-20-2013, 10:58 PM
Robert6401's Avatar
Robert6401 Robert6401 is offline
Robert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to all
It is a good mod, especially for a handshaker, but probably not necesary unless you're towing heavy and have some really good grades. I had it and it was nice, but the EBPV stuck closed on me a couple of times for some reason so I stopped using it. I have since removed the EBPV, so it's no longer an option for me. It's definitely worth trying out and a fun mod to do on the cheap. Just keep in mind you need to have RPMs up above 2300 or so for it to really be effective.
  #64
Old 06-21-2013, 10:06 AM
Christof13T's Avatar
Christof13T Christof13T is offline
Christof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant future
My truck has kwik's original mod with tc lockup switch added.
I knocked one of the leads loose behind the dash while removing or replacing it one of the umpty million times... and am unsure where it went.
Before i broke the lead... it worked wonderfully... except the tc would not unlock without totally shutting down the truck and restarting. Kinda maddening...
I would kinda like to gut it and start over with an updated tc lockup device.
Or would you guys just recommend a decel tune? (When i can finally get a hydra anyway)
Heater Hose Disconnect Tool Vegas Van Aerostar 24 12-29-2015 09:40 PM
Ignition Coil starting voltage ss0345 1987 - 1996 F150 & Larger F-Series Trucks 0 08-15-2015 10:34 AM
Dual Battery Disconnect bismic 6.0L Power Stroke Diesel 8 04-09-2015 01:47 AM
EGR delete Kit Installation TIPS phantomphixer 6.0L Power Stroke Diesel 16 04-04-2015 02:21 PM
Pics of Spike (If I did it right!) GrampsHandMeDown 6.7L Power Stroke Diesel 15 09-06-2011 05:12 PM
Tags
73, a, brake, convert, diesel, ebpv, exhaust, f550, ford, ivs, mod, solenoid, superduty, transmission, valveexhaust, warm, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
