Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 08-27-2004, 08:34 PM
BroncoRoadKill's Avatar
BroncoRoadKill BroncoRoadKill is offline
BroncoRoadKill is starting off with a positive reputation.
Just put the pics in your gallery. You can use photo shop too resize it.
__________________
82 Bronco 351w C6
95 f-150 300I6 5spd 2wd
My truck likes mud.
  #17 (permalink)
Old 11-04-2006, 10:09 PM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
Any new news on thease projects?
I have a 99 2.5 in my Ranger and a local guy burned me a chip last week, he has no experience with this engine. Does any one know what direction I can give him to fine tune this chip?
We are working with 89 octane gas, seems to ping with over 24 degrees of timing.
Thanks Dan
  #18 (permalink)
Old 11-04-2006, 11:46 PM
hotrodfeguy hotrodfeguy is offline
hotrodfeguy is starting off with a positive reputation.
I would say go with better gas first
Give some 93 a try one time if it still pings, the chip time is way to high/advanced.
__________________
64 FAIRLANE 428
67 F250 352 8 1/2 FT PLOW
  #19 (permalink)
Old 11-05-2006, 02:46 PM
This is the third burn, I am hoping to be able to stay with 89 for cost reasons. I don't think my mpg or power will increase enough to warrent $.15-$.20 higher gas per gallon.
Seems to only ping at part throttle climbing hills. Wide open throttle I cannot hear it ping. He did not change any fuel trim except for leaning it some at wide open throttle due to it being pretty rich.
Power seems about the same but mpg has come up .5-1mpg
Thanks Dan
  #20 (permalink)
Old 11-06-2006, 10:43 AM
Well my guess then
Sounds like you are running into a lean detonation. Try the higher octane for a tank or even try a blend of some e-85 or race gas maybe a gallon to a tank. e-85 I know it sounds crazy but the E-85 does have a higher octane rating, and may just get you by. its worth a try.
__________________
64 FAIRLANE 428
  #21 (permalink)
Old 11-06-2006, 10:59 AM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
93 here is only 20 cents more per gallon than 87...honestly I think 89 octane is a waste of money, but that's just my opinion.
__________________
1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs. 4" intake tube, ATS upgrade, 4" exhaust w/ Walker 21172, boost & pyro on pillar, Autodim mirror, 16x8 MB Razor wheels w/285/75R16 "MT-R's"
1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners
2008 V-Star 1100 Midnight Custom-Just Cobra slip-on drag pipes for now
  #22 (permalink)
Old 11-06-2006, 11:35 AM
ghunt, here in Sioux Falls SD. 87 octane is pure gas and cost $2.26 gal. 89 octane is 10% ethanol and cost $2.19 per gal. with no decrease in mpg from 87 pure gas. Premium is only 91 octane here and cost $2.36+ it may or may not contain 10%ethanol depending on station.
This is why I want to stick with the 89. I cannot gain enough performance or mpg to offset the cost of 91 octane gas.
If we can get this thing sorted out we will experiment with E85 (85%ethanol 15% gas) that is 105 octane. But I will lose MPG, he thinks he can keep me with in 3mpg of the 89 and the cost of E85 is $1.78.
Thanks for all the help, I plan on going to his shop on Wed. this week for some more fine tuning. All sugestions are apprecieated, little info on this site to tuning thease old Pinto fours.
Dan
  #23 (permalink)
Old 11-11-2006, 11:58 AM
went back to the shop and had some more tweaking done. Ping gone and MPG is still up,better than truck has ever done. He also put his E85 tune on the chip and installed the switch to switch between stock, 89 tune and E85 tune. I want to run at least one more 89 octane tank through before trying out the E85.
  #24 (permalink)
Old 11-11-2006, 03:38 PM
pud pud is offline
pud is starting off with a positive reputation.
uhhhh...I didnt know mazda's got the lima. I know the B2200 got a 2.2L and that Ford used mazda engines in the probes....but this is the first time Ive heard that there is a 2.3L mazda engine. Are you sure it is? by actually comparing the two, and not just by taking the guys word for it either. I want to see pics of this mazda and its engine.
I told the ricer that bought my mx6 I had swapped in a Ford engine because it was beefier and mo powerful. I had really just replaced the mazda badge on the valve cover with a Ford one.
__________________
2004 Focus zts (60 miles a day round trip to work, stuff it)
  #25 (permalink)
Old 11-12-2006, 01:25 AM
ghunt's Avatar
I know the Mazda B-series trucks came with the Ford V6's for a few years, I thought they were also available with the 2.3, but I could be wrong...
__________________
  #26 (permalink)
Old 11-12-2006, 02:49 AM
pud pud is offline
the newer mazdas, the ones that look like the rangers, have a 4.0L ford in them. Ford and mazda shared alot of parts in the late 80s and early 90s. You could appropriately call them Fazda's and Mord's lol.
I havent seen a mazda with the 2.3L tho, I would be skeptical, and am. Ive never heard of one having a 2.3L either.
__________________
  #27 (permalink)
Old 11-12-2006, 09:06 AM
Ford makes the Mazda Ranger on the same assembly line as the Ford Ranger. The Mazda version with the 2.3, 2.5 Pinto engines are called B2300 and B2500. Matter of fact on my 1995 Mazda B2300 the only mention of Mazda any where was the sticker on the tailgate, all dataplates clearly said mfg by Ford Motor company in the USA
  #28 (permalink)
Old 11-12-2006, 11:19 AM
pud pud is offline
that doesnt suprise me. I was stuck on the first gen mazda's, which got 2.2L I4s and 2.6L v6s.
__________________
  #29 (permalink)
Old 01-10-2007, 08:15 PM
fordnut71 fordnut71 is offline
fordnut71 is starting off with a positive reputation.
if u have the 1st gen 8 plug heads they are just junk u really need the later version of them they also come with the roller cam
the compression on a turbo motor is 8.1 an na is 9.1
the turbo piston is a factory forge an the na is cast .... if boosted most is 6psi to b safe
there is a lot of high performance an factory parts for the 2.3
  #30 (permalink)
Old 01-11-2007, 06:48 PM
ghunt's Avatar
Quote:
I wouldn't say "A lot."
There's plenty of stuff if you want to build a 9000 RPM, unstreetable oval-track race motor, yeah...
Otherwise it's still a developing market.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
