cheap fix for cracked bell housing - Ford Truck Enthusiasts Forums
Old 08-05-2004, 10:21 PM
Phinxter's Avatar
Phinxter Phinxter is offline
Phinxter is gaining momentum as a positive member of FTE.Phinxter is gaining momentum as a positive member of FTE.
I couldn't really find a home for this thread so I'll try it here.
I discovered my C4 trans bellhousing has 2 cracks in it. One is an alignment hole (no big deal) to the engine and one is threaded for the starter. It must have been that way for awhile, and I've had no problems from it, but since it is out of the truck I wonder what I can do short of taking it someplace to have it welded to temp fix this.
Old 08-05-2004, 10:24 PM
Jimbare's Avatar
Jimbare Jimbare is offline
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
if you have a c4 tranny, remove the bellhousing and find another to replace it with. lots of tranny shops will sell you one. salvage yards will sell them also.
jim
Old 08-05-2004, 10:28 PM
Phinxter's Avatar
ok sounds good any idea what that should cost??????
Old 08-05-2004, 11:12 PM
Jimbare's Avatar
anywhere from 10 bucks to 50 bucks. but it would be fixed right.
jim
Old 08-06-2004, 12:55 PM
Saurian's Avatar
Saurian Saurian is offline
Saurian has a good reputation on FTE.Saurian has a good reputation on FTE.
What's wrong with a quick weld?
Old 08-06-2004, 02:27 PM
Phinxter's Avatar
welding sounds good but I'm too cheap (broke). upon further inspection what had been done is to just put a bolt thru and a nut on the back, it worked before its gonna stay that way, thanks!
Transmission Housing Cracked--HELP! 1961FordGirl 1961 - 1963 F100 Unibody 5 03-13-2014 10:48 PM
Medium Duty Truck Frame repair Biggoomba 1947 and Older Ford Trucks 5 10-05-2013 01:08 AM
Cracked leather steering wheel and seats cattlerancher 1999 - 2003 7.3L Power Stroke Diesel 14 11-22-2009 09:48 PM
JB Weld to fix crack in aluminum intake dadstan76 Fuel Injection, Carburetion & Fuel System 5 10-17-2009 06:33 PM
96 F150 dashboard Cecil50 1987 - 1996 F150 & Larger F-Series Trucks 11 01-28-2006 11:14 AM
Tags
bell, bellhousing, broken, cracked, f150, fix, fixing, ford, hole, housing, repair, repairing, saturn, transmision, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
