Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Iowa Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
  #1 (permalink)
Old 08-05-2004, 06:26 PM
fordloverf2501970's Avatar
fordloverf2501970 fordloverf2501970 is offline
Garage is empty, add now
fordloverf2501970 is starting off with a positive reputation.
going to pella saturday
well i gotta run up to pella to dougs trucks on saturday to pick up a new transmission, going to scrounge around looking for this and that also. have to replace mine, someone who was helping me got in a hurry and ended up snapping half the ears off the bellhousing and put a big crack in it too. no it wasnt me, i was in the house talking on the phone. I need some migrane headahe stuff, if it isnt one thing it is something else. jeeze
__________________
Iowa chapter member
FTE supporter
If you can read this, thank a Teacher
if it is in english, Thank a Soldier !
Currently truckless and Laid Off!
but i am happy!
  #2 (permalink)
Old 08-05-2004, 09:57 PM
Lifted78's Avatar
Lifted78 Lifted78 is offline
Lifted78 is starting off with a positive reputation.
I think I have what you're looking for!
PM me the specifics so I can measure it with a tape measurer to know which one I have. I have a couple C6's in the garage.
John
  #3 (permalink)
Old 08-06-2004, 01:55 AM
monsterbaby's Avatar
monsterbaby monsterbaby is online now
1967 Ford Galaxie
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
if your transmission is ok other than the problem you described, just find a case that will fit your engine it doesn't even have to be from a truck or have the same tail shaft, then gut them both, and transfer all of you internals to the new case, and you are good to go, and watch dougs they have a tendancy or reputaion for covering up problems until you get it home (like painting over rust without fixing it)
__________________
Rob
Learn from your parents mistakes.......... Use birth control
  #4 (permalink)
Old 08-06-2004, 01:16 PM
hey lifted it is a total of 29 inchs long from the front of the bell housing to the rear of the output shaft, it is a c6 short tail shaft let me know i still waiting on dougs to call me and he wants 250 clams. i would rather buy it from a someone like you then dougs. but i need it right away too, cant stand not having a vechile to drive tired of bumming rides to work. call me if you want cell number 319-209-1185 or at home at 319-752-0574
__________________
Iowa chapter member
FTE supporter
but i am happy!
  #5 (permalink)
Old 08-06-2004, 05:25 PM
Lifted78's Avatar
To follow up on the phone conversation, turns out I have a small block C6 with 26 inches end-to-end.
Good luch with Dougs!
John
  #6 (permalink)
Old 08-06-2004, 10:01 PM
john i cant use anything for a small block,but thanks for trying. i am leaving for dougs in the mornng, anyone wanna go ? or have a little meet up there, i hoping to leave before 8am i should be there by 10 am, going to look around for some odd and ends too.
__________________
Iowa chapter member
FTE supporter
but i am happy!
  #7 (permalink)
Old 08-06-2004, 10:08 PM
1967 Ford Galaxie
If you want to come through chariton, and I will take you out to pollards yard here he has alot of trucks, and his prices aren't bad.
__________________
Rob
  #8 (permalink)
Old 08-06-2004, 10:39 PM
well can i take a rain check on that ? i would like to get to another truck yard besides dougs, i have heard good things and bad things about dougs. i am hoping i get to be part of the good things, at least i get a 90 day warrenty on the tranny. i already got him to get it brought up for me i just got to pick it up now.
__________________
Iowa chapter member
FTE supporter
but i am happy!
  #9 (permalink)
Old 08-06-2004, 11:42 PM
benwantland's Avatar
benwantland benwantland is offline
benwantland is starting off with a positive reputation.
Quote:
You can't go wrong with pollards! I've gotten loads of stuff there for $20.
I wonder what he'd charge for a 300 that I could rebuild at my leisure without having my truck down...
__________________
New Truck: 1992 F-150 x-cab longbed 4x2. 351W/E40D
Old Truck: 1977 F-100 Longbed 4x2. 300/4 speed OD manual trans. Clifford intake. Hedman header. Road Demon 525 4 bbl. Dual 2.25" exhaust.
  #10 (permalink)
Old 08-09-2004, 10:07 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I made the mistake like that once, on a Windsor, my cousin welded it back on for me, worked out ok. Never made that mistake again, that was a long time ago...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #11 (permalink)
Old 08-12-2004, 07:02 PM
stryder's Avatar
stryder stryder is offline
stryder has a good reputation on FTE.stryder has a good reputation on FTE.stryder has a good reputation on FTE.
Dougs is a complete rip-off! Try Witt's outside Eddyville. I went to Dougs for a front hub when I still had my '77. He wanted some outrageous price and didnt even know if he had one. Called Witt's and is was about half price. He even exchanged it after I found a crack. Dont even get me started about the "truck" he has for sale!
Stryder
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
