1999 F550 brake problem. need help bad. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-05-2004, 05:20 PM
foot947 foot947 is offline
foot947 is starting off with a positive reputation.
Question 1999 F550 brake problem. need help bad.
rearleft caliper was leaking so replaced it bled all 4 brakes. pedal went to floor i could not get any brake pressure. two different brake people bled brakes again, still cant get any pressure on pedal.they replaced master cylinder,replaced the new caliper with another new caliper, replaced abs pump,bled brakes again and again. if any one could help please feel free to give any suggestions . i have not been able to use truck for 2 weeks .
Old 08-05-2004, 09:04 PM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
You probably have air trapped in the ABS system. It takes special equipment to activate the valves so the air can be purged. Dealers have the equipment. Try doing a couple of hard stops to activate the ABS, then bleed the brakes again.
Old 08-19-2004, 08:21 PM
problem solved. the new caliper was wrong. it fit but bleeder valve was on bottom instead of at top, you could probabley bleed 55 gallons of fluid and still not push air out. so remember to check location of bleeder valve when replacing caliper. my 550 was down 2 weeks cause of this. a lesson not tobe forgotten.
Old 08-19-2004, 10:27 PM
whitmo whitmo is offline
whitmo is starting off with a positive reputation.
I just replaced the rear passenger caliper on my 2000 F250 tonight. Went smooth, no problems.
My question is if there is anything I need to do to make sure that the parking brake is still adjusted right? The caliper instructions mentioned it, but did not explain how to check.
Old 08-20-2004, 07:41 PM
Sorry, not able to help you with that. Good Luck!
Old 08-20-2004, 08:42 PM
Replacing the caliper has no effect on the parking brake. The parking brake is located inside the rotor. There is a pair of small brake shoes and the inside of the rotor is machined like a brake drum. There is an adjustment slot in the backing plate.
Old 08-21-2004, 03:36 PM
Thanks for the info!
Old 08-21-2004, 11:12 PM
Tlattin Tlattin is offline
Tlattin is starting off with a positive reputation.
Whitmo- if the parking brake pedal gets firm when setting the parking brake, it is properly adjusted. If it gets tight late in the pedal travel, you can adjust them with the star adjusters behind the rubber plugs near the bottom back of the brake assembly like all drum brakes you have ever seen. Just did two trucks recently. Changing the rotor may change it, but not the caliper (as slc10844 said).
Old 01-22-2013, 06:04 PM
kenmt kenmt is offline
kenmt is starting off with a positive reputation.
Just a note that might make it easier for those who are adjusting their parking brake.Looking from the rear towards the front,the passenger side adjuster needs to be turned clockwise to tighten and the driver's side needs to be turned counterclockwise.
02 F250 soft brakes bigcrushjake 1999 to 2016 Super Duty 2 05-13-2016 11:55 AM
HELP!! 2000 E150 Both Front Calipers Stuck kincfu 1968-2013 Full Size Vans 7 03-23-2016 07:59 PM
2003 Brake Caliper Sticking daveplot Expedition & Navigator 6 08-21-2015 06:46 AM
HELP bleeding brakes please 69oiler Excursion - King of SUVs 12 02-03-2013 05:22 PM
Brake issues! Vacuum pump problem? LSO1123 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 08-08-2011 10:09 PM
Tags
1999, 2000, 550, abs, adjust, adjustment, bleed, brake, brakes, emergency, expedition, f550, ford, issues, lines, parking, rollback
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
