how do i pump up the lifters? - Ford Truck Enthusiasts Forums
Old 08-05-2004, 02:26 PM
jsutton's Avatar
jsutton jsutton is offline
jsutton is gaining momentum as a positive member of FTE.
I have quick question about when i get ready torque down the rocker arms on my 77 D7OE heads on an 83 grand marquis 302 block. in the past pack rat and i have had the same question about these heads and i know i am just supposed to torque them down to 23 ft lbs but in packrats post someone said to have the lifters pumped up when you torque them down and i am wondering just how to pump them up. Are you just talking about using a drill to turn the oil pump to get oil up to them like priming the engine before you start it or what? hopefully the engine will be going in next week!! thanks for all the help!!!
jason
77 f100
long bed
Old 08-05-2004, 10:58 PM
speedyredford speedyredford is offline
speedyredford is starting off with a positive reputation.
Yes, just find someway to turn the oil pump, just build a little pressure for a couple of rotations. I used to take the coil wire off and crank it for a couple of seconds, but if your engine is not running, then a drill is your option, besides cranking a V8 by hand... that's not fun.
Good Luck.
Old 08-06-2004, 01:47 AM
fastvert fastvert is offline
fastvert is starting off with a positive reputation.
Soak them in motor oil over night. The lifters pump themselves up.
Not trying to insult your knowledge, but you do know each rocker has to be on the base cirle of the cam (valve closed) before you torque, right? Also, you should reach torque spec at 1/2 to 3/4 turns past zero lash.
Old 08-06-2004, 09:18 AM
jsutton's Avatar
Thanks, i just making sure about how to pump them up. i appreciate all the help. i can not wait to get this in and hear it run!!!!!
jason
77 f100
Old 08-14-2004, 09:35 PM
battered_bronco battered_bronco is offline
battered_bronco is starting off with a positive reputation.
get them in a huddle and give them a pep talk
Old 08-15-2004, 09:07 AM
altonjh1 altonjh1 is offline
altonjh1 is starting off with a positive reputation.
Another way to fill the lifters is to place all of them in a coffee can and fill the can with motor oil to a point above the top of the lifters. Place the can on your drill press and place an old piece of pushrod into the chuck. Just use the leverage of the drill press to press down on each lifter. It will quickly fill each lifter with oil. I have done this many times.
Collapsed lifter - 1977 302 - Flat tappet bhenders 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-04-2016 08:12 PM
How do you check the lifters and rollers? RoryTheFerret Modular V8 (4.6L, 5.4L) 1 04-06-2016 05:54 PM
another pedestal rocker adjustment thread 73 fourxfour 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 38 02-20-2011 03:55 PM
Installed Chebbie rockers and new lifters on my '79 today. thunderb Ford Inline Six, 200, 250, 4.9L / 300 5 12-13-2007 02:45 PM
problem setting lifter preload eastvanmikee 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 11 07-03-2005 11:33 PM
Tags
100, 1966, 46, 54l, 73, ford, lifter, lifters, miles, oil, pump, pumping, sohc, tappets, triton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
