1978 - 1996 Big Bronco
M5OD or ZF5
Old 08-04-2004, 01:43 PM
oledog's Avatar
oledog
oledog is offline
M5OD or ZF5
1995 5.0 5 speed. How do I tell if its the M5OD or ZF5?
Thanks
Old 08-04-2004, 08:57 PM
gman88's Avatar
gman88
gman88 is offline
Look at the ID plate located on the side of tranny. The M5OD will be marked E87A XX, where the XX is the ford part number. The ZF will show model ZF and perhaps something like S5-42. The casting for the ZF has a raised diamond pattern and the M5OD has a raised rectangular pattern.
ID tags should be located on the drivers side.
Old 08-05-2004, 12:32 PM
andym's Avatar
andym
andym is offline
Unless it was swapped, it's a Mazda (M5OD). The easiest way to tell is the M5OD does not have a granny gear, the ZF does.
Old 08-05-2004, 01:49 PM
Stokes's Avatar
Stokes
Stokes is offline
if its in a bronco, its probably a M5OD. unless it was swapped, the ZF's where only offered in 3/4ton and heavier trucks.
Old 08-05-2004, 04:13 PM
oledog's Avatar
oledog
oledog is offline
Thumbs up
Hey thanks guys. I know I should've read the manual and got under there but I always think of these questions at work.(besides the net is much faster here)
Jjona5
12-11-2016 09:27 PM
John_0063
11-30-2016 10:25 AM
#01truckfan
13
10-19-2015 04:34 PM
jgavac
07-31-2014 12:52 PM
79 f-150 guy
05-08-2011 07:53 AM
Quick Reply: M5OD or ZF5
