97 Explorer Lift Kit - Ford Truck Enthusiasts Forums
Old 11-12-2001, 04:55 PM
sathb sathb is offline
sathb is starting off with a positive reputation.
Post 97 Explorer Lift Kit
I have a 97 Explorer and would liek to lift it about 3 inches. As far as I can tell there is no kit for anything newer than 95. Anyone know anyway I can make this happen?
Thanks
Old 11-13-2001, 06:15 PM
cpnhgnjnky's Avatar
cpnhgnjnky cpnhgnjnky is offline
cpnhgnjnky is starting off with a positive reputation.
Try going to the fourwheel drive shops if you have any around town. Or you can buy a 4x4 mag there is an almost endless supply of parts dealers to chose from. Or try to contact them on line, most of the dealers will have web sites that you can visit. Try this one its the only one I can remember off the top of my head, www.performanceaccessories.com this is a manufacturer if body lifts that com ewith good instructions. If you only look at big mags like Summit and such they only bother stocking the most popular. I just ordered a 2002 Sport-trac and the above web site has a body lift for it. Hope this helps.
cpnhgnjnky
Old 11-14-2001, 12:27 PM
reberhardt reberhardt is offline
reberhardt is starting off with a positive reputation.
No one makes a lift kit for the '95-'97 Explorers due to the torsion bar mounts being welded on. In '98 Ford started bolting them on so Trailmaster makes a 4" suspension lift for the '98-'01 Explorers. It can be easily modified to work with the '95-'97 Explorers by a competent 4x4 shop. It is pricy though, about $1300 for parts only.
You can also use a 3" Performance Accessories body lift from the Ranger on your Explorer. You would need kit #853 ('93-'97 Ranger) with the front bumper brackets from kit #883 ('98-'00 Ranger) or kit #883 with the steering extension from kit #853. Use whichever method results in the lowest cost. Either way you will have to create your own rear bumper lift brackets. They are easy though, just two pieces of 3"x7" 1/4" plate steel with 4 9/16" holes drilled in them. You also need to come up with some extra bolts since the bolt lengths aren't the same between the Ranger and Explorer. I used kit #853 and made my own bumper lift brackets on my '97 4x4 Sport. I paid about $125 for my kit.
Finally, you can turn your torsion bars up to gain 1"-1.5" in the front. You would then use Warrior Shackels part #153 to lift the rear to match. This would cost you about $50. I did this as well. I have 32" tires on it now, and will be going to 33" tires when these wear out.
Old 11-14-2001, 12:55 PM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
'95-01 Explorer Lift Kits Explorer Freak Explorer, Sport Trac, Mountaineer & Aviator 2 01-10-2011 11:45 PM
95 Explorer Lift kits? Crazed1122 Explorer, Sport Trac, Mountaineer & Aviator 4 12-14-2007 05:08 PM
Explorer Express Lowering Kit explorerrulz97 Explorer, Sport Trac, Mountaineer & Aviator 2 07-28-2003 03:26 PM
Explorer Lift Kit SeabeeBuilder133 Explorer, Sport Trac, Mountaineer & Aviator 6 01-08-2003 09:08 AM
where can i buy a lift kit for my 1995 ford explorer?? jberylecrider Offroad & 4x4 15 08-18-2002 11:44 PM
Tags
1997, 97, body, brackets, easy, explorer, ford, front, kit, kits, lift, mountaineer, summit, support, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
