99 f150 blower resistor location - Ford Truck Enthusiasts Forums
Old 08-04-2004, 08:44 AM
5jordan 5jordan is offline
5jordan is starting off with a positive reputation.
Question 99 f150 blower resistor location
can anyone tell me the location of the blower resistor? my blower doesn't work on speed 1 and 2. it does work on high. switch is fine. thank you
Old 08-05-2004, 01:46 PM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
It should be near the blower, attached to the air handler box, under the hood. Probably rectangular with a wiring harness attached to it.
Old 08-05-2004, 08:11 PM
passenger side under glove box. black plastic removable panel 3 screws. blower is a round motor with a wire harness connected to it. there is another wire harness that goes to the resistor. right in front of the blower towards the pass. seat. 2 screws removes the resistor. it is connected by a beigh plastic board. the resistors are 3 spring like devices on the other side. mine shorted out the black wire connector. there is a 4 wire harness to the resistor. i ordered one from a ford dealer $18. i hope this works?
Old 08-05-2004, 11:29 PM
Pikachu's Avatar
Yup. You found it. Some are under hood, but I guess not that one.....
blower motor resistor location on an '87 E250 diesel? becida 1968-2013 Full Size Vans 3 07-26-2015 09:06 PM
Blower motor only works on 3&4 gtmustang00 Expedition & Navigator 8 02-20-2012 04:41 AM
Blower Motor Resistor Location '08 Escape... 2002sport Escape & Escape Hybrid 4 10-23-2010 12:01 PM
blower motor resistor taxahawhorseman Cooling, Heating, Ventilation & A/C 1 09-02-2009 10:09 AM
Heater blower only high nickh 1987 - 1996 F150 & Larger F-Series Trucks 10 02-01-2009 08:43 PM
Tags
99, 99f150, blower, f150, module, problems, resistor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
