Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-04-2004, 03:26 AM
n6nfg is starting off with a positive reputation.
Oil accumulating on top of the engine
I am noticing a bit of oil starting to accumulate on the top of the engine. I don't know where it is coming from, but it seems to start at the front of the engine (where the intercooler hose enters the block maybe) and is kind of "streaked" back, some on top of the oil filter housing, and finally ending on the black plastic cover that is over the turbo. I haven't noticed any being sprayed up on the hood blanket (yes I had to buy it extra!) I keep wiping it off, but today I noticed enough had accumulated on the cover over the turbo to cause a single "drop" to develop under this cover. It is not a lot of oil, and I can continue to wipe it off, but I didn't know if this was an indication of trouble starting. I did notice that the plastic hose end from the intercooler was slightly "cockeyed" on the engine block right angle fitting. If I wipe around this area, there "may" be some oil here, but not much. This is the only place I can figure it is coming from. I can straighten the coupling back on the housing, but it only moved less then 1/32" when I straightend it. This is a 05/04 build with the silver colored air hoses with blue couplers. Any ideas?
__________________
-n6nfg
2004 F350 4x4 Lariot CC SB 6.0 Auto
Wedgewood over Silver, moonroof
  #2 (permalink)
Old 08-04-2004, 08:31 AM
matt1751 is starting off with a positive reputation.
Most likely is coming from the intercooler tube(CAC tube) where it connects to the elbow on the maifold,, see photo's in my gallery.. I have seen many leak here,, mine was actually leaking on the lower connection at the intercooler but just tighting it will not usually fix the leak,, you will need to remove the tube, clean it with Break Klean, let dry and then reassemble tighting the clamps good,, I have had no further leaks and has been at least 4k miles since I did this , the other place it could be leaking is from the oil filter cap if not tight but must likely the CAC tube
  #3 (permalink)
Old 08-04-2004, 08:44 AM
IB Tim's Avatar
Administrator
IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation
Good call Matt.......and spot on
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
  #4 (permalink)
Old 08-14-2004, 01:51 AM
I had dealer reposition and retighten the hose (yes the one noted above from the intercooler, thanks). They cleaned up the oil, and we'll see if it comes back.
__________________
-n6nfg
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
