The easyest trucks to work on in my opinion are the freight liner classics TONES of room every where you can see and touch the inposible ISM/m11 starter bolt that always seems to be tourqued to 12billion foot pounds.
I agree about the classic. I just rebuilt the power divider in a friends truck. He has a Classic XL. Nice truck.
I have several Mac and Snap-on 5/8 12pt. impact sockets with the teeth shucked out of them from starters. They can be one of the worst jobs a person can get in the wrong truck, like a car hauler.
I got into the M11 head gasket problem they had back in 99 I think it was. We helped out the IH dealer that was behind us. They had a bunch of them that had to get done so they asked if we could help them out. I made a piece for a fork lift so I could take the head out of the right cab door. I have it around here somewhere.
__________________
79/83/86/95 F-??? 6.9 4speed
94 350 4x4 SRW 7.3 factory turbo
1930 Model A Original
My wife has three of her own.
I agree. I like the KW's except for the T2's. They came out with them to early before they got the bugs worked out. They tried keep up with the VN Volvo body. We were a KW and Volvo dealer when that all came about. The VNs are nice trucks. The T2s are like driving a beach ball.
KW wanted to get rid of the T6s but to many people complained and they would have lost customers.
What are your drive train parts? When I was there most of the W9s had N14s 13 or 18 trans and Eaton 404 drives with 355 gears. That was a common and good combo.
I agree the t2000 werent good lookin as were the "anteaters". As they say its not a kenworth unless its a w9!! 1984 f250 (in process of restoration) 6.9 strait piped i can run it now around the house and is loud as hell!!!! 3" body 3" homemade suspension lift fuel screw turned and advanced timing. 272000 rough, hard miles
92 F350 4x4 7.3 na auto 4.10 gears, 230k swapped 7.3 for 6.9 with Banks Sidewinder needed more power. Auto started slipping installed controller for trans stayed the same, swapped in a ZF 5sp with single mass flywheel sounds like it has gravel in trans using synthetic oil in trans sounds the same works and runs good. Fixing to swap in a 93 nonpowerstroke turbo motor due to old engine using oil 2 qts in 250 miles and fuel mileage with tailwind 15 going 65 the original set-up got 18 at 70/75 mph.
90 F350 Lariat crewcab 2wd Dually, 7.3L na, auto 4.10 rear, peeling paint, true miles?? 20480 on the dash - it could be 220,480 but runs like it has only 20480, non working power door locks, and nice a sounding true dual 2.25 exhaust - Just bought 2 weeks ago - This is my first diesel engine experience and so far sooooo good!
94 f250 non aspirated new dual exhaust new interior all around new 15000 pound hitch same sucky e4od tranny new transfer case new used bed new rims lookin 4 some good lookin 35s startin to tow a 12000 pound loaded trailer and addin a trans cooler tomorrow
__________________
94 SC 7.3 4x4 IDI DIESEL stock with e4od 355 gears 38" tires
