Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 08-08-2004, 10:08 AM
macman85602's Avatar
macman85602 is starting off with a positive reputation.
1986 ext. cab F250 6.9 4spd 250000? miles 4:10 rear Jensen cd head unit 250watt amp 2 11" subs and 2 6 1/2" alpine door speakers
__________________
Shoulda bought a Ford!
83' F150 - RIP - Gone to scrapyard in the sky
86' F250 6.9 4spd 3/4 ton - Brakes are a great option
It has a bow tie cuz you wanna give it away
  #32 (permalink)
Old 08-08-2004, 11:02 PM
Ironpants is starting off with a positive reputation.
Talking
Daily Driver = '94 F350 CC LB XLT 4X4 SRW w/ '91 7.3L pushing 450,000 KM in front of automatic and factory turbo w 4" exhaust.
Work Truck = '91 F250 Lariat Ext Cab LB 4X4 converted to a deck 7.3L pushing 435,000 KM in front of a ZF5 - push button start (no keys) - toggle switch glow plugs, toggle switch fast idle, toggle switch AC
Parts truck = 2nd '91 F250 Ext Cab XLT LB 4X4 7.3L
Spare Parts = ZF5 tranny is on my tranny stand, '94 turbo that was in the '94 is on my engine stand
As you can see, I got too many parts to even *think* about buying something else...
Chad
__________________
Chad
'94 F350 CrewCab, LongBox, Single Rear Wheel, XLT 7.3L w/ factory turbo. Currently with a '91 7.3L installed, E4OD, airbag suspension. truck's got 430,000 KM, engine has 590,000 KM.
  #33 (permalink)
Old 08-09-2004, 05:38 AM
trike1946 is gaining momentum as a positive member of FTE.trike1946 is gaining momentum as a positive member of FTE.
1990 E350, with 179,000 miles. Used to be a mini bus, now a work truck.
  #34 (permalink)
Old 08-09-2004, 07:36 AM
turbo69's Avatar
turbo69 is starting off with a positive reputation.
92 F-350 XLT 4 wd converted to 6.9 330k on orig 7.3 360k on truck now
__________________
Keep on truckin'!
Bobby
"The Gray Ghost" '92 F350 CC 4x4 E4OD - Lots of mods and more to come
"The Buckin' Bronc" '90 Eddie Bauer 302, auto, 4x4
  #35 (permalink)
Old 08-09-2004, 09:48 AM
bowedup2003 is starting off with a positive reputation.
!984 F350 Crewcab Single wheel 1 Ton, originally 351W and C6, now 6.9L IDI NA with ZF 5 speed, Luk Solid flywheel, Dual 2.5" Straight exhaust, Injectors for early 1980's IH dumptruck, mildly tweaked pump, 4.10 gears, engine has about 15,000 miles since rebuild/conversion
Bowedup
  #36 (permalink)
Old 08-09-2004, 10:54 AM
88'7.3F-250 is starting off with a positive reputation.
1988 F-250 7.3L C6 4WD SC LB 98K miles
  #37 (permalink)
Old 08-09-2004, 02:53 PM
fellro86's Avatar
Iowa Chapter lead
fellro86 has a very good reputation on FTE.fellro86 has a very good reputation on FTE.fellro86 has a very good reputation on FTE.fellro86 has a very good reputation on FTE.
86 F250, 6.9 diesel, maybe 10,000 on rebuild, unknown chassis, but quite a few, 4wd 4 speed, 4.10 axles Dad's 84 6.9 C-6 3.55 4wd approaching at least 300,000 original miles, rebuilt trans at 250,000
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, A518 auto (for now)with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed
Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
  #38 (permalink)
Old 08-09-2004, 06:11 PM
Electraglider is starting off with a positive reputation.
1990 F250, 7.3 idi, N/A, E4OD, w/148000 Miles no frills. work around the house and camper truck.
  #39 (permalink)
Old 08-11-2004, 10:09 AM
Raised with Ford is starting off with a positive reputation.
1986 6.9l 4x2 SC LB 140k
  #40 (permalink)
Old 08-11-2004, 09:00 PM
Old Man Ford is starting off with a positive reputation.
1988 E350 Dually. Was full bodied schoolbus. Cut down and made cab out of doors and rear off of E150. 9 foot hauler deck and fifth wheel. 7.3 IDI C6 auto. 295000 and going strong.
OMF
  #41 (permalink)
Old 08-11-2004, 10:53 PM
1984 f-250 is starting off with a positive reputation.
1984 6.9 5 spd, had 450000 miles then rebuilt and now have 2000 miles.
  #42 (permalink)
Old 11-21-2004, 04:22 PM
pipewelder71 is starting off with a positive reputation.
1989 F-250 4x4, 7.3, 5 speed 20,000 miles on engine with a CTS turbo,114,000 miles on truck, 6 inch lift with 35 inch tires.
  #43 (permalink)
Old 11-21-2004, 06:19 PM
nogo73's Avatar
nogo73 is starting off with a positive reputation.
1992 F350 regular cab long box 4x4(dana 60 front, sterling 10.25 rear) borg-warner 1356 tranfer case 4.10:1 gears. 1986 6.9 rebuilt diesel. zf-5 speed 420 close ratio with a clutch masters 12" flywheel and a kevlar clutch.about or almost 10,000 miles on motor. stans headers dual 3" exhaust. almost 167,000 on the odameter.
I wondered why I missed this one I was on the road trucking nowhere near my computer.
__________________
1992 F350 Reg. cab 4x4 6.9 Diesel 5 speed 4.10:1 gears.Gone,but not forgotten!
2004 Expy XLT,5.4,3.73,4X4 (Dad's)
2005 Escape XLT,3.0,4X4 ( Sister's)
2005 Focus ZX4 (Brother's)
2002 Jeep Liberty Limited,4X4(Mom's)
Iowa chapter Board Member
  #44 (permalink)
Old 11-21-2004, 09:33 PM
Dieseldan7.3's Avatar
Dieseldan7.3 is starting off with a positive reputation.
Talking Backroads Beater
1989 Bondo Bucket f250 4x4 w/ NA 7.3 5speed 4.10 33"BF Goodies Custom bumper/hitch 200000 trailer towing miles
Made in the USA with tools not chincsticks
__________________
1994 F250 xlt lariat, 7.3 turbodiesel 5speed, 4x4, pyro and boost, 0-60 in 11 seconds,33" BF GOODIES, K+N, 3.55s, 5th wheel, Pioneer sound system, 1/2 turn on ip,soon to be 5" turnouts.
  #45 (permalink)
Old 11-21-2004, 10:51 PM
brojrm is starting off with a positive reputation.
1989 F250 7.3, 4 speed std. with overdrive. Had 384,000+ miles when I totaled her on March 1st. Engine still cranks and runs good.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
