Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #271 (permalink)
Old 05-01-2008, 08:37 PM
benwill1's Avatar
benwill1 is starting off with a positive reputation.
trying to take the turbo off of my 94 is a pain!!! I has a cracked head/ blown gasket passanger side
__________________
94 F-250 4X4 ext cab long bed 7.3 idi factory turboFactory 410 gears with limited slip rear automatic only 165,000 miles
  #272 (permalink)
Old 05-02-2008, 12:42 AM
catfish101's Avatar
catfish101 is starting off with a positive reputation.
Quote:
Originally Posted by George D. View Post
The easyest trucks to work on in my opinion are the freight liner classics TONES of room every where you can see and touch the inposible ISM/m11 starter bolt that always seems to be tourqued to 12billion foot pounds.
I agree about the classic. I just rebuilt the power divider in a friends truck. He has a Classic XL. Nice truck.
I have several Mac and Snap-on 5/8 12pt. impact sockets with the teeth shucked out of them from starters. They can be one of the worst jobs a person can get in the wrong truck, like a car hauler.
I got into the M11 head gasket problem they had back in 99 I think it was. We helped out the IH dealer that was behind us. They had a bunch of them that had to get done so they asked if we could help them out. I made a piece for a fork lift so I could take the head out of the right cab door. I have it around here somewhere.
__________________
79/83/86/95 F-??? 6.9 4speed
94 350 4x4 SRW 7.3 factory turbo
1930 Model A Original
My wife has three of her own.
  #273 (permalink)
Old 05-02-2008, 12:48 AM
ron01sd's Avatar
ron01sd is starting off with a positive reputation.
1992 F-250 Custom 7.3L 5 Speed 4x4 174,000
__________________
2001 F-250 7.3L XLT 4x4 Ext Cab Longbed Automatic, 3.73 Gears, 6637, DP Tuner(Stock,Highidel,40hpTow,80hpEcono), 4" From Turbo No Muffler 5" Tip, Foil Delete, 3 Gauge A-Piller(Boost,Trans,Exhaust) 2" Leveling Kit, LT285/75r16 Muds, Ranchhands Front And Rear
1992 F-250 7.3L Custom 4x4 Reg Cab Longbed 5 Speed, 3.55 Gears, Stock For Now
  #274 (permalink)
Old 05-02-2008, 04:29 PM
6.9ford84(smoker) is starting off with a positive reputation.
Quote:
Originally Posted by catfish101 View Post
I agree. I like the KW's except for the T2's. They came out with them to early before they got the bugs worked out. They tried keep up with the VN Volvo body. We were a KW and Volvo dealer when that all came about. The VNs are nice trucks. The T2s are like driving a beach ball.
KW wanted to get rid of the T6s but to many people complained and they would have lost customers.
What are your drive train parts? When I was there most of the W9s had N14s 13 or 18 trans and Eaton 404 drives with 355 gears. That was a common and good combo.
I agree the t2000 werent good lookin as were the "anteaters". As they say its not a kenworth unless its a w9!! 1984 f250 (in process of restoration) 6.9 strait piped i can run it now around the house and is loud as hell!!!! 3" body 3" homemade suspension lift fuel screw turned and advanced timing. 272000 rough, hard miles
  #275 (permalink)
Old 05-02-2008, 08:48 PM
dieselhappy is starting off with a positive reputation.
1988 F350 Crew Cab, ZF5 5 speed manual tranny, 7.3 IDI added ATS 088 non-wastegated turbo, A-pillar autometer gauges (pyro & boost), added A/C. Converted v-belt system to serpentine belt system. 340,000 KM. Synthetic Oil in tranny and diff. Lov'n it!
  #276 (permalink)
Old 05-14-2008, 08:30 PM
l'il ol diesel is starting off with a positive reputation.
91 F-350 7.3 idi 4x4 E4OD regular cab 192,000 miles 18 mpg 55mph@1600 rpm
  #277 (permalink)
Old 05-16-2008, 08:51 PM
lunatech's Avatar
lunatech is starting off with a positive reputation.
1994 F350 7.3 IDI, factory turbo, 5-speed manual, crew cab, long bed, dual tank, 151000 miles. Just bought 1.5 weeks ago.
  #278 (permalink)
Old 05-18-2008, 09:47 AM
rpep1982 is starting off with a positive reputation.
1992 Supercab 4X2 F350 Dually 157,000 miles
  #279 (permalink)
Old 05-18-2008, 03:28 PM
WesHoffman49's Avatar
WesHoffman49 is starting off with a positive reputation.
1988 F250 XLT Lariat 7.3 IDI C-6 SC, 4x4 150,250 miles
__________________
Wesley Hoffman
2001 F-250 Super Duty 7.3 Turbo Diesel
1980 F-100 Custom 4.9 I-6
"Nobody comes between me and my powerstroke"
"Now, Thats a good idea" - Horatio Caine
  #280 (permalink)
Old 05-18-2008, 06:54 PM
altruego's Avatar
altruego is starting off with a positive reputation.
1988 F250 Lariat 7.3L 4x4 (Canadian built) 158,000 and going strong.
  #281 (permalink)
Old 05-18-2008, 08:09 PM
marino1958 is starting off with a positive reputation.
stock 94 F-250 super cab long bed 7.3 factory turbo 190,000 mi.
  #282 (permalink)
Old 05-18-2008, 08:19 PM
JoeJ is starting off with a positive reputation.
7.3 to 6.9 to 7.3
92 F350 4x4 7.3 na auto 4.10 gears, 230k swapped 7.3 for 6.9 with Banks Sidewinder needed more power. Auto started slipping installed controller for trans stayed the same, swapped in a ZF 5sp with single mass flywheel sounds like it has gravel in trans using synthetic oil in trans sounds the same works and runs good. Fixing to swap in a 93 nonpowerstroke turbo motor due to old engine using oil 2 qts in 250 miles and fuel mileage with tailwind 15 going 65 the original set-up got 18 at 70/75 mph.
  #283 (permalink)
Old 05-20-2008, 04:04 PM
bOOgiZ is starting off with a positive reputation.
90 F350 Lariat crewcab 2wd Dually, 7.3L na, auto 4.10 rear, peeling paint, true miles?? 20480 on the dash - it could be 220,480 but runs like it has only 20480, non working power door locks, and nice a sounding true dual 2.25 exhaust - Just bought 2 weeks ago - This is my first diesel engine experience and so far sooooo good!
  #284 (permalink)
Old 05-20-2008, 05:42 PM
knapikmichael is starting off with a positive reputation.
94 f250 non aspirated new dual exhaust new interior all around new 15000 pound hitch same sucky e4od tranny new transfer case new used bed new rims lookin 4 some good lookin 35s startin to tow a 12000 pound loaded trailer and addin a trans cooler tomorrow
__________________
94 SC 7.3 4x4 IDI DIESEL stock with e4od 355 gears 38" tires
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
