2000 Explorer ticking noise - Ford Truck Enthusiasts Forums
Old 11-26-2001, 05:00 PM
Exploritory Exploritory is offline
Exploritory is starting off with a positive reputation.
I could use some help. I have a 2000 explorer 4wd XLT. I hear a clicking or knocking noise seemingly from the oil pan. This only occurs however, when I put the vehicle in gear. It will completely disapear if I put the truck in park or neutral. The noise seems to follow rpm's, again only if the truck is in gear. A local mechanic wants to charge me $650.00 to take off the oil pan. OUCH! Of course he doesn't know thats where the problem is. The truck has 80,000 miles almost all highway. Oil changed every 3000 miles. I did switch to synthetic at about 75000 Could that be a problem? Please Help. I would appreciat any input.
Old 12-04-2001, 07:06 PM
fraser fraser is offline
fraser is starting off with a positive reputation.
I'm probably just as good at guessing whats wrong as some of the doctors around here, but the oil pan does'nt sound like the problem area, it sounds like the transmission to me ie; when it's in gear it makes the noise. I'd try changing the tranny oil first.(Synthetic too!) But what do I know!
Old 12-05-2001, 04:23 PM
The problem has ended up being a streched timing chain and worn out tensioner. In fact its being fixed as I'm writing this. its great to finally find a mechanic who knows something.
Old 12-05-2001, 04:34 PM
stevensonr stevensonr is offline
stevensonr is starting off with a positive reputation.
Cam Phasers, Timing Chain, Bad Fuel Economy ??????????? jessecam 2004 - 2008 F150 0 07-22-2014 08:18 PM
tapping noise at high rpm bengineer 1968-2013 Full Size Vans 7 06-16-2013 07:00 AM
4R70W Gear Noise from transmission coelacanthes 1968-2013 Full Size Vans 7 04-29-2013 06:43 PM
390 oil amosmoses FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 13 02-21-2012 07:30 PM
2002 explorer humming noise Mustang6t7 Explorer, Sport Trac, Mountaineer & Aviator 5 10-01-2009 05:02 PM
Tags
2000, 2005, explorer, ford, noise, ticking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
