Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-02-2004, 03:17 PM
DUKEIN DUKEIN is offline
Garage is empty, add now
DUKEIN is starting off with a positive reputation.
Lightbulb Electrical problem.......
Since i am a newbie to this forum, i'd like to says hello to all user.
So anyways, i just bought a 1988 Ford 4-b(R)anger and having electrical problems. The problems seemed to discharge batteries overnight. Thinking that it maybe just an old battery, went to get a new battery installed. Drove the car, went home, tried starting the the next day and the battery is dead. So we decided to disconnect the battery at the end of the day. Next day worked with my dad on the problem and found this very interesting issue. Whenever the + battery terminal is disconnected, the wiper seems to have a life of it's own and run uncontrollable (non-responding to wiper controls) until you connected back the + terminal to the battery.
Had anyone seen and experianced this problem?
Any comments/suggestion/help is appreciated!
  #2 (permalink)
Old 08-02-2004, 06:50 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Welcome to FTE!
The wipers work with the + battery terminal disconnected?!?!?!
The guys in the Electrical Forum would like to hear about that.
AL.
__________________
97 Ranger (metric half ton) 2.3,5spd. Saphire blue metalic w/matching cap & Stock Rims 4 winter.
92 Town Car....Sweet PITA.
90 BII 4x4 Ongoing Project, aka PITA
63 Fairlane, Gone to my buddy Chuck.
It Aint Fun Unless It's Done The Hard Way!
  #3 (permalink)
Old 08-02-2004, 07:22 PM
We recorded the battery voltage, then compared with the engine on, we expected additional voltage, we do (something like 2-4 more).
So to check if the alternator does work, we removed the + terminal off the battery (engine still running) saw wipers started uncontrollably.
  #4 (permalink)
Old 08-31-2004, 11:31 PM
Hardwareman Hardwareman is offline
Hardwareman is starting off with a positive reputation.
Seems impossible unless there's a hidden battery.
  #5 (permalink)
Old 09-02-2004, 07:13 AM
FordF150Fixer FordF150Fixer is offline
FordF150Fixer is starting off with a positive reputation.
I don't think its a good idea to ever remove the battery while the engine is running. I think the alternator regulator and battery work in a closed loop to control the voltage the alternator pumps into the battery. I assume that without the battery to regulate the alternator, the alternator's output voltage probably jumps up to some higher than normal level. The windshield wippers are controlled by a relay with a solid state time delay circuit. The higher than normal voltage is probably causing the time delay circuit to do some unusual things. This is all a guess, maybe some of the more experienced users can add some thoughts..........
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
