I have an 89 F-150 4x4 with a 302, I have recently rebuilt the motor and am having trouble with it fowling the plugs. I have about 5500 miles on it since the build and i have put four sets of plugs in it. I had a computer chip burned to the exact specs of the motor but it only seemed to make the problem worse. The engine is hard to start at times and when it finally does it stombles around and misses until you rev it up several times and it stops blowing black smoke out the pipes. I put a slightly larger cam in it than stock and I was worried about not having enough vaccum (SP?) So i hooked up another vaccum canister and that helped a little but my a/c controls on my dash still go crazy and i am still changing plugs. SO a friend of mine that is an o'l timer said I needed to swap out the EFI for a
Holley 650 double pumper. I have purchased it along with intake, new ignition system, stall converter, and a bigger cam. But i am affraid of the unknown problems I am going to encounter with my AOD tranny. Any tips would be gladly appreciated. The Cam specs on the cam I am now running are:
Duration lift @.050 212/218 , Valve lift 474/474, Duration @ .006 Tappet lift 260/268 Lobe separation angle 114.
The cam I have purchased to put in once I install the carb is:
Duration Advertized 280/280, Duration lift @.050 230/230 Valve lift@ 1.6 512/512, Lobe separation angle 110. I have headers, the holley 650, and a 2400 rpm stall converter.
I drive the truck maybe once a month I just want something that has a great sound at an idle and with my 5.13 ring&pinion can turn my 38.5's in overdrive. The truck can do it now but it struggles and has the starting problem. I wish I had spent he extra money and just stroked it out to a 347 instead of building a 306.
