Fuel Filter Change
I changed my filter recently after 30,000 miles of service as part of regular maintenance (no performance problems). I don't know how clogged it was, but a bunch of particulate material came out. I think I will change mine a little more often. I try to use better gas at newer stations, but dirt seems to get in anyway. I would say after 45,000 you are due for a new filter.
Its easy to change yourself with a special tool available at most auto parts stores.
Read this thread:
https://www.ford-trucks.com/forums/s...e+fuel+filter+
The filter is located under the driver on the frame. You must go under the car on your back and look up to get to it. It is a round metal can about the size of a soda can with a hoses on each side.
Read this thread:
