Major Oil Leak !!!!
Major Oil Leak !!!!
Just picked up oil and filter to change the oil in my truck !! When I got home I noticed that my truck was ****ing oil all over the driveway..... Somewhere between work and my house which is about a 20 min drive, I sprung a major leak at the rear of my oil pan. I'm guessing it is the main seel ??? Anyone ever heard of a problem with oil pan or main seel leaking in the newer 7.3's If I stop for 15 mins I leave a puddle about 6 inches round on the ground !! Bad news !!
Russ
Russ
It looks like it's coming from the back of the pan, right where it joins to the trans... I guess it's possible that if the pan is really rusty there it could have broke the seal... Sound reasonable ??? So I guess I should just drop the pan and reseal it and see if that fixes the problem ??
Originally Posted by Pikachu
Did you check for rust on the pan? There is a TSB about the pans rusting.
I couldn't see and oil above the pan level !! But I will double check up top and see if there's any oil up there as well... Thanks for the tip !! All info is very helpful.. thanks...
Originally Posted by djf48
Check on the top of the motor, in the fuel filter area. See if there is any oil up there! Mine did about the same thing and it was the HPOP (high pressure oil pump).
Thanks man !!! It was definately the HPOP... 1 of the o-rings was screwed and it was peeeeing oil out of there... Great help !! Totaly appretiate it !! I'll be back on the road in no time !!! After I clean up the big mess !!! There's oil everywhere !!! Have a good day !!
I think I still need to change the oil tonight... who knows what got into the system with all that leaking going on... Better to be safe than sorry !!! I really don't need to replace the turbo prematurely.... Thanks guys !!
Originally Posted by refuse2
Well look at it this way at least you were going to change the oil.
refuse2
refuse2
02GrayPowerStroke
30
07-30-2008 11:37 AM
GPSMatt
04-24-2008 05:00 PM
heybrent
1978 - 1996 Big Bronco
06-25-2003 05:16 PM
BW50
04-16-2002 04:31 PM
