How much exhaust back pressure is too much????
Originally Posted by John7894
Will running it for 5 minutes without the O2 to check backpressure hurt anything other than make it run like crap? I just want to check the pressure, not drive it w/o the O2
A better way to do it is to drill two holes small holes in the exhaust pipes on either side of the cat. With the engine idling put your hand over each hole and see if you can tell a difference in pressure, it should be fairly even, if it's pushing harder in the front hole (towards engine) it's clogged.
An aftermarket high-flow cat is about 60 bucks from summit racing.
This also belongs in the exhaust forum, moved
giles45shop
Escape & Escape Hybrid
09-11-2016 08:19 AM
BigCountry1978
07-08-2016 04:51 PM
John7894
17
07-09-2011 03:44 PM
mxracer3276
27
01-11-2010 09:35 AM
