Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-30-2004, 12:55 AM
91ford_ranger is starting off with a positive reputation.
Poor idling? low power? no codes? read this
While searching mitchell repair I found this: Customer's vehicle had poor idling, low on power (1992 4.0) No codes showing. The repair shop test drove and confirmed customer's complaints. They installed breakout box and found voltage was too low on some pins to register problem code(100mv) Problem was poor grounding inside the ECA, and the EFI relay. Replaced both and problem was solved. Makes me wonder what I'm up against...
  #2 (permalink)
Old 07-30-2004, 01:51 PM
mrshorty is starting off with a positive reputation.
Any more details? When they said "no codes" did that mean no codes whatsoever or all pass (111) codes? Which pins were low on voltage?
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #3 (permalink)
Old 07-30-2004, 02:03 PM
No codes at all? I'll look for that example and post pin #'s. They diagnosed through mitchell online feature. I would cut and paste whole story, but cut and paste doesn't work on mitchell format?
Also it was bad EEC power relay and ECA, not efi relay. My f.u.
  #4 (permalink)
Old 07-30-2004, 02:08 PM
No trouble codes at all would be consistent with no power to the PCM which would be consistent with the need for a new relay.
__________________
  #5 (permalink)
Old 07-30-2004, 02:39 PM
I printed article. I hesitate to post copyright material on internet. Will email you if you're interested.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
