How many miles before cleaning air filter?
I know most of you don't run K&N air filters, but I currently am running a K&N and wanted to see how many miles you suggest between recharges. I have had the filter in for about 8000 miles with about an hour of dirt road driving. I am heading to baja for about 10 hours of off-road driving and I am wondering if I should recharge now or when I get back.
I would seriously consider getting rid of that thing and getting a better filtration system before going out to baja. If you don't have time to replace it with a different filter, at the very least make darn sure you have that thing completely sealed up. A lot of folks here (myself included) had/have problems with getting the K&N's to seal properly with the stock airbox. The other thing I noticed with mine was since the turbo sucks in so much air, it needed to be cleaned more often, so if you stick with that filter, I'd clean it now and let it get a little dirty again before going out there so it filters a little better. Just my .02.
Terry
Terry
What alternatives are out there? I need increased air intake to go with chip and exhaust, but I need extra protection from dust as well. What do I check to see if dust is getting through? Also, can anyone answer my first question....In normal driving circumstances, how many miles do you go between cleaning your air filter? 15,000??? Thanks for your opinions, information.
Performance will depend upon your chip or tune. I would have to say that the AIS flows less then an open air set up like Cookie's.
Filtration is what's key in your case with going to Baja etc. I'm on a lot of construction sites, etc. here in AZ, NM and NV so I was willing to give up a little flow for 99.9 filtration.
Your call, AIS does not void warranty, but if you're chipped, you have none anyway.
This response for the AIS was from a DieselStop thread dated 7/1/03:
Hello Folks, Please allow me to introduce myself. My name is Jordan Flagstad, I am a Senior Automotive Engineer at Donaldson Company in Bloomington, MN. Donaldson designed and manufactures the new AIS for the Ford 7.3 liter Turbo Diesel pickups that looks to be the focus of discussion along this thread and a couple others in this forum.I was asked to join this forum to act as a technical laison (Talk Shop) with you folks concerning the new AIS for the 7.3 liter Power Stroke. I must say, I graciously accepted this assignment as being a turbo diesel pickup owner myself I think I share a lot of interests here.OK, enough about me....Let's talk about this new AIS. With this new system, you are putting "Big Rig" performance under the hood of your pickup. This new system offers 3x more dust load, lower restriction and newer technology than the original system. Some of the concerns / questions I have read in this forum are:* Is the restriction of this new AIS higher than the standard system? The answer to this is no, the new systems restriction numbers are considerably lower than the standard system.* Does this system provide a longer service life than the standard system? Yes, the new AIS has a service life on the order of 3 times the dust loading capacity of the standard system.* What is the filtering efficiency of the new AIS? The filtering efficiency of the new AIS is 99.9%+. The system will load approximately 900 grams (just about 2lbs.) of dust to the trip of the Filterminder. With a 99.9% efficiency rating this would mean that less than 1 gram of dust would pass through the AIS to the clean air side. Competing with this new AIS on the market today, are various aftermarket induction systems that utilize washable filters. I have tested some of these filters and found their filtering efficiencies to be as low as 70%. This would mean on a 900 gram dust load, 270 grams (just over 1/2 lb.) of dust will be ingested into the engine. Now this would be devastating to any engine and more so to an engine with a 100,000+ rpm balanced turbo charger.* It looks like the Filterminder trips at a lower pressure, Is this true? This Filterminder is specially calibrated for this system. The Filterminder is calibrated to trip when the restriction at the outlet of the cover reaches 25" H2O.
Originally Posted by cookie88
I'm not going to bash the AIS since I don't have one, and I certainly do not want to start yet another filter was, but I do have a couple of huge problems with that post.
Jump on the MSN Stu and I'll tell you all about it.
