third brake light
third brake light
Here's how I read the schematic. Light-green wire out of brake switch goes to splice S212 (about 8 wires into this splice). Out of the splice one light-green goes to the lower brake lamps, through connector C212. Also out of the splice is a dark-green going to the same connector. The dark-green continues from C212 and heads to connector C320. Out of that connector it goes to the High Mount Stop Lamp. The lamp should be grounded via a black wire. Interior fuse 13 feeds the entire circuit so it must be fine since you get lower lights.
Take your lamp back apart. Verify 12V on the dark-green wire to a good ground when pedal depressed. If 0V, check for those connectors. If 12V then check the ground wire. Verify continuity between the black wire and a good ground.
This ought to do it. Good luck.
third brake light
>WHEN I SAID I REPLACED THE LIGHT, I MEANT THE ENTIRE METAL
>BAR, WHERE THE WIRES ATTACH.
>THANKS,
>J BRANHAM
I'm not quite sure what you replaced now. The florescent light and ballast are two separate items although they might come together if purchased from Ford for about $280. I haven't had to replace mine yet but from what I remember it is a rectangular black box probably under the trim in the rear hatch. The light is riveted on to the back hatch by about 7 rivets. Either one could fail. If you replaced only one, then the other is likely the problem.
Robert
>THANKS,
>J BRANHAM
Robert
Ballast on 95 - 97 Explorers typically go bad before the neon light assembly. Ford only used this third brake light set up for those years. Thank goodness since they are expensive to replace and trouble-prone. If you replaced the light assembly then, like reberhardt said, it is likely the ballast. You may want to ensure that you have 12 volts DC before the ballast. The ballast increases the voltage tremedously before sending it to the light assembly.
Mason
Mason
Thanks for everyone's replies on helping me with this problem.
It turns out the problem is with the Lamp Outage Module that sits below the console. I notice on many web forums a lot people have had trouble with this. I think it is because the wires that plug into the module card is very tight, and after time the pins lose connection.
I have been able to fix my problem by bending the pins so they connect again. The card appears to be working fine.
SCFROST
09-24-2014 01:07 AM
REALTREE-F150
05-18-2014 09:44 AM
jrf250
03-12-2014 08:20 PM
