Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 07-28-2004, 09:08 AM
nuclearmonster's Avatar
nuclearmonster nuclearmonster is offline
Garage is empty, add now
nuclearmonster is starting off with a positive reputation.
Best Chip For Propane
I have read that to run propane safely, you need a chip burned for propane. I am running a SCMT now but want to add propane. I hate to give up the tuner but want to be safe. Any suggestions on a good chip(multiple settings)to run with propane?
Nuke
__________________
99 F250 4WD, SCMT, Sonnax/Tricumulator, 4" Straight Pipe (side exit), HX MOD, Tymar Intake, Camo Rocker Panels
  #2 (permalink)
Old 07-28-2004, 12:29 PM
powershotone powershotone is offline
powershotone is starting off with a positive reputation.
The SCMT on either 60 or 80 will work fine with propane. At that horsepower level, timing is not advanced excessively to make power.
Higher horsepower or extreme chips and 4 pos chips (100hp and above) increase timing and fuel delivery (hence the high EGT's) as well as other perimieters and it would be advisable for those chips to have the timing advanced removed from the programming if possible.
  #3 (permalink)
Old 07-28-2004, 05:11 PM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
nuclearmonster-
If you want the best chip to run with propane, get hold of Dale at TYMAR, and get one of his Diesel Power chips. I'm in the process of replacing my Diablo Delta chip with one of his. I had it here yesterday, and after driving my truck with that chip in it, there's no way I could live without it. That thing rocks!!!
There are a lot of chips that can be tuned from propane use, but if you're going to spend the money, you might as well get something you'll really be happy with.
__________________
When you're walking away from your truck, do you turn around just to look at it? Yeah, so do I. ☺
'13 F-250 Platinum CC SB 4X4 Powerstroke.
  #4 (permalink)
Old 07-29-2004, 06:11 AM
Thanks quad, I will give him a call.
Nuke
__________________
  #5 (permalink)
Old 07-31-2004, 10:05 PM
Jlower's Avatar
Jlower Jlower is offline
Jlower is starting off with a positive reputation.
Quad, how'd you like that chip? I called Dale after reading your post. Kind of feeling the mod bug once again. I'm finally going to commit to the powershot and have my DSl PWR chip reprogrammed for it. I was wondering if you could tell me the dimensions and capacity of your propane tank? How far is is stood off the frame?
__________________
03 F-350 CC LB Lariat 7.3 PSD 4X4 DRW/ Plenty O' goodies---Dare to race ?
SIGINT/ELINT - In God we trust, all others we monitor.
  #6 (permalink)
Old 08-01-2004, 07:28 PM
Quadzilla's Avatar
I've got a 9.9 gallon Manchester tank that is hung from brackets bolted to the frame. The distance between the tank and the frame is about 4".
Dale has a bejillion different programs he can load for you, and I'm still in the process of picking and choosing the ones that work best for me. One I've got in the truck now increases the pulse width of the injectors beyond what my Diablo chip can do, so there's a noticieable increase in power over the hottest Diablo program. Smoke? Oh yeah, baby!!
__________________
  #7 (permalink)
Old 08-02-2004, 08:27 AM
Jlower's Avatar
Smoke.......! I now have a solid black soot line all the down both sides of my street. The bicylist have learned not to stray out of the bike lane ! I love this chip !
__________________
Tags
chip, propan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
